powering up an esp project 99 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th November 2012, 12:56 PM   #1
Default powering up an esp project 99
hello, just a quick question..
if you had to power this up from scratch..
Subsonic / Rumble Filter for Phono preamps and Sub-Woofers
would it be a good idea to use this dc/dc converter? so i can go in from a wallwart with 12v dc in?
http://www.digikey.com/product-detai...9-5-ND/1927080
any other suggestions on how to powrer this thing up if as a standalone type device if that won't work?
it needs 15+/15- dc... with a ground..
i take it i hook the ground to the 0v pin?
thanks!!!!
Old 24th November 2012, 02:27 PM   #2
sorry if this is a stupid question..
i'm a newb and trying to plan this thing out. i feel like that is exactly what i need...
Old 24th November 2012, 03:28 PM   #3
Easiest, (and safest for a beginner):
Project 05:
Power Supply for Preamps
Old 24th November 2012, 03:43 PM   #4
ok, so i went ahead and ordered the power supply board.. i was hoping to cut a few corners to save cost, but then i thought about it and decided i would ultimately be a lot happier with the p05.. knowing that the new updated board has a muting circuit and filters for noise.
i wonder if i can use an led as the load required for the muting circuit?
Old 24th November 2012, 03:44 PM   #5
Old 24th November 2012, 04:22 PM   #6
Deleted: Misread something on the 5B circuit.
Old 24th November 2012, 05:37 PM   #7
Minion is offline Minion  Canada
If you can get a 12v AC Wall Wart you can build a voltage doubler to get +/-15v DC that will work fine for a low current draw circuit .....
Old 24th November 2012, 06:14 PM   #8
well, i'm kinda new to the diy scene.. i have a beginners guide to electronics, so i know a little bit, but i'm not super savvy yet, so whipping up my own concoction is not the best idea right at this stage.
i have been practicing soldering for the last couple days to get better, soldering point to point and on rat shack printed circuit boards.. i'm getting quite good i would say. i built an adjustable soldering station using a 25 watt weller soldering iron and an adjustable light dimmer switch with a volt meter to know how much voltage is going to the soldering iron..
i'm currently in the process of lining up all the parts i need on digikey for this whole project.
i want this to be a standalone unit, so i'm going to go for a 15-0-15 transformer built into the chassis, with an iec mains connection on back of the unit. the main power switch will be cutting the mains supply to the transformer.
this is all kinda new, so it seems a bit intimidating, but i know from other hobbies and such, you just have to jump in and ask questions..
i am practicing a lot of safety when working with electricity, i know that is a must.
if anyone has any advice to offer, it would be greatly appreciated.. possibly steer me in the right direction if i appear to be going the wrong way...
thanks!
Old 24th November 2012, 07:11 PM   #9
...as suggested in post 3.
The project 5A can use a single 12 VAC supply as well, as described in the project page at ESP.
XTZ Room Analyzer acoustic measurement system was $299.99 now $239.99 Zodiac Vendor's Bazaar 0 17th August 2011 07:06 PM
****Silver wire 4n 99.99% 0.5mm x 25m for sale **** zanash Swap Meet 7 3rd July 2005 07:55 AM
ESP project 5 LaZarus Solid State 11 20th June 2002 12:33 AM
Copyright 1999-2017 diyAudio
