Multiple regulators - What is the end-output-impedance?
Old 23rd November 2012, 05:56 PM   #1
kumori is offline kumori  Europe
Default Multiple regulators - What is the end-output-impedance?
Hallo,
I have a question about using multiple voltage regulators after another.
Is the output impedance, that the circuit "sees" just the output impedance of the last regulator used?
For example:
Transformer ---> CRC Filter ---> Gyrator serial reg --> Shunt regulator
Let´s say we have 1 Ohm Serial R in the CRC Filter, the Gyrator has an output impedance of 1 Ohm, followed by a shunt reg with 0.001 Ohm output impedance.
What does the powered circuit know about the 1+1 Ohm serial resistance, when the the last regulator stage has very low output impedance?
I guess also the size of the reservoir or decoupling caps comes into play, but can anyone give a reliable "rule of thump" or something similar?
Florian
Old 23rd November 2012, 06:00 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
The shunt regulator determines the output impedance.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 23rd November 2012, 06:01 PM   #3
OK, well that was easy.
Thanks.
Old 23rd November 2012, 06:16 PM   #4
jcx is offline jcx  United States
the (active) shunt reg determines the small signal output impedance
but once you try drawing more than the shunt reg bias current it cuts off and the output Z rises
Multiple regulators - What is the end-output-impedance?Hide this!Advertise here!
SET output impedance vs speaker impedance Arno Pf Tubes / Valves 3 20th April 2012 07:37 PM
Closed end TL experiments, impedance flattening Dr_EM Multi-Way 90 5th January 2011 04:14 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
Multiple driver connection, impedance Dr_EM Subwoofers 5 3rd June 2009 09:44 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
