Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th November 2012, 12:48 AM   #1
Default 7815T in a TO-220 package
Can a 7815T use AC power? I am trying to drop a bipolar 30 vac power supply to 15vac bipolar.
Old 20th November 2012, 01:32 AM   #2
glennb is offline glennb  Australia
No, 7815 and its ilk are DC regulators. To drop an AC voltage you should use a transformer. Resistors could also be used if current is constant and you don't mind wasting power. Can you explain what you mean by bipolar?
Glenn.
Old 20th November 2012, 04:30 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
This circuit will divide an AC voltage by 2 (or any other ratio).
It is probably a good solution to the wrong problem, but here it is anyway:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 20th November 2012, 06:46 PM   #4
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
LM317 can regulate AC current, it's pdf has already a sugestion in the matter.
Trance Session Live by Dj Marik
Old 20th November 2012, 08:35 PM   #5
Robert Kesh's Avatar
that will make a very very dirty AC, will need much filtering
Old 20th November 2012, 08:47 PM   #6
sofaspud's Avatar
~15V zener diodes back to back will chop the AC, but it would help to know just what/why the OP is trying to achieve.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 20th November 2012, 10:24 PM   #7
MarianB's Avatar
Maybe so but it is an viable option, anyway until @Bradford336 gives us much more detailes than that sketchy short first message we cannot really help him.
@Bradford336 you need to be much more specific, what do you need that 15Vac for? where do you get those 30Vac from?
Old 22nd November 2012, 09:48 AM   #8
30vac from a center tap transformer powering a 15vac volume control board that will pull 1A
I keep hearing "just use a couple resistors" but have no idea how to size them. The transformer is powering a 15-0-15dc power supply for an amplifier circuit already. I am trying to add the volume control board to it. Sorry about the sketchy messages I just do not know what you need.
Old 22nd November 2012, 10:56 AM   #9
Elvee's Avatar
Your VC board probably requires a floating AC input, if grounds have to be interconnected.
This leaves you only one option: a separate transformer.
If it doesn't need floating supply (unlikely), you can use one side of your 15-0-15 transformer.
For that kind of power, any other option is unreasonable.
Old 22nd November 2012, 08:23 PM   #10
ty everyone you guys always straighten me out
Looking for recommendations on TO-220 package GSD (Hitachi) pin-out MOSFETs BoilermakerFan Solid State 1 21st May 2010 04:43 PM
WTB: BUF-634 buffers in TO-220 package KT Swap Meet 1 24th July 2007 05:15 AM
transistor package anton Parts 8 11th August 2006 06:47 AM
the complete package? ccarrigan Multi-Way 8 21st July 2006 04:29 AM
high speed diode to-220 package for Aleph-x rwagter Pass Labs 29 10th February 2004 03:50 PM
Copyright ©1999-2013 diyAudio
