Help to known my transformer power - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th November 2012, 08:55 PM   #1
Default Help to known my transformer power
Hi guys! I've a 12-0-12 3A transformer... I'm planning to use him to power 2x TDA2003 suposely 10W amps, totalizing a 20W power need. But i also think if isn't a good idea use some 2x 20W amps, but idk what chip amp could that be or if my transformer can handle it.
i've a regulated power supply that i'm planning to unmount to do it. it has a 30-3V regulated voltage to 3Amps.
Old 17th November 2012, 11:04 PM   #2
Robert Kesh's Avatar
24x3A = 72VA, to be safe half that, as current and voltage may be out of phase, so 36W. The 10W amp probably dissipates another maybe 6W.
So you should be OK, though you could have a much bigger transformer to cope with transients.
Old 19th November 2012, 12:07 AM   #3
Why should i consider the potency half of the VA capacity?
Yeah, i'll deal with the 2x TDA2003, hoping it will be at least good HiFi
Old 19th November 2012, 12:23 AM   #4
DUG is offline DUG  Canada
http://www.hammondmfg.com/pdf/5C08.pdf
Check catalog page 11.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 19th November 2012, 12:36 AM   #5
Yeah... there's some serious loses on the process... I'm thinking about a simmetrical mount +-13V capacitor load output. It Will fit a +-32W Audio system?
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 07:13 PM
High Power Transformer/Power supply PCB for Sale. Count Tubeula Parts 2 26th October 2012 08:45 AM
power transformer as output transformer seedseed Analogue Source 18 7th May 2011 07:52 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 09:57 AM
Good price on huge power transformer for power amp. G Solid State 3 15th September 2002 02:23 PM
Copyright 1999-2017 diyAudio
