Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th November 2012, 05:39 PM   #1
Mitchel is offline Mitchel  Brazil
Mitchel's Avatar
Default Power Transformer Noise (not Hum)
Hello Everyone,
I just finished a Leach amplifier (I drew a new PCB), as you can see in this picture, which was taken prior to the wiring.
The amp sounds amazing, but after testing it on a scope with a resistive dummy load, I found that the power transformer (EI) is making a weird noise, that strangely changes according to the sine wave injected on the signal input.
This is what I did: I connected the 8 ohms dummy load to the amplifier output. With a function generator, I injected a sine wave to the amp input. The transformer started to produce a noise, in the exact frequency as I injected. I tried to vary the freqeuncy, and the noise changed accordingly. Also, the noise increases with the amplitude of the sine wave. It's not really loud, but it's weird.
Anu clues? Thanks!
Old 15th November 2012, 05:45 PM   #2
Mooly's Avatar
Are you sure its the transformer ?
Its actually quite common to "hear" TO3 package output transistors "sing" in the way you describe. They can be quite loud.
A simulation free zone. Design it, build it, test it.
Old 15th November 2012, 09:02 PM   #3
Mitchel's Avatar
I'm gonna test it again, but I was pretty sure it's the transformer! I'll wrote again later! Thanks
Old 15th November 2012, 09:16 PM   #4
nigelwright7557's Avatar
Have the bolts through the transformer been tightened down properly ?
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 15th November 2012, 09:54 PM   #5
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
btw, that's a nice looking build
mlloyd1
Old 16th November 2012, 12:50 AM   #6
I had this happen recently with some chip amps that had an on-board output inductor. It was the inductor that was making sound, especially above 1k Hz. It's like a little voice coil!
-Charlie
Old 16th November 2012, 02:45 PM   #7
Mitchel's Avatar
Hello guys,
You are right, it's not the transformer. It's hard to point out exactly the source of the noise, but it's definitely from the amplifier board - the TO-3 output devices or the output inductor.
Is this normal? What should I do?
Old 16th November 2012, 02:47 PM   #8
Mitchel's Avatar
Now that I know it's not the power supply, I will post this thread on the right forum.
Which power transformer for low hum? johngalt47 Analog Line Level 1 14th May 2012 05:39 PM
PassAleph 3 power amp with hum noise, please help Pass lover Pass Labs 18 19th May 2009 02:17 PM
hum noise from my amp. hc167 Solid State 18 9th September 2008 06:12 PM
Hum Noise! Matthewong Tubes / Valves 9 15th May 2007 01:01 AM
Anything post power transformer that can cause it to hum / buzz? loomis Tubes / Valves 6 24th March 2006 05:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
