Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th November 2012, 07:17 PM   #51
SY's Avatar
So do competent regulators. Jack's measurements and listening tests were pretty clear-cut; for lowest noise, this isn't even close to the answer.
If there's a sucker born every minute, where do the rest of them come from?
Old 16th November 2012, 07:29 PM   #52
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
Originally Posted by Robert
You really do like to have the last word don't you (pot kettle):-). However have you ever studied the characteristics of a Jung super regulator or variations thereof? If you have you will know that they are very twitchy regarding output capacitors, anything with too low an ESR asks for oscillation.
Any way my point is solely that the Bybee should not be condemned by this fact alone.
who said it was that alone?
yes, yes I do haha... but I dont think that really applies in this post, i'm simply replying.
I've used all manner of regulators including the Jung, numbers of wide bandwidth regulators/amplifiers don't enjoy driving capacitance, but there is enough info to make a proper decision, mostly because youve probably built it yourself.
I would not agree with a one size fits all Jung reg sold as an upgrade for circuits that are not going to suit it either and I have recommended builders here to avoid putting caps on the output. by itself its not a big deal, but given the broad sweeping recommendations they make for using it....thats a bit more problematic
the Jung reg has the advantage of being extremely high performance to make up for it, you might consider modifying your build to accommodate it, a trait not shared by this device.....
Secondly, I agree fig 8 has an extremely wide loop area but it is an illustration of a high voltage application, not particularly likely to be used in a DAC but not at all atypical of tube circuits or even power amps where one often sees filter caps many centimetres from the output devices and equally remote from a ground point. Not that I condone such practices of course!
tube 'IV' stages are pretty popular here from what i've seen, but I take your meaning.
tubes are pretty darn wide bandwidth too are they not? even moreso due to often being used with low feedback.
but yes lets not go there... I sense we agree tubes are pretty alien to me, but I have witnessed and....erm.. wondered about such circuits...
Old 16th November 2012, 08:53 PM   #53
scott wurcer's Avatar
Originally Posted by john curl View Post
However, they are inherently very quiet, much quieter than most lab supplies.
Ah, that isn't saying much. My Aglient triple supplies are useless for low noise work.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 16th November 2012, 08:57 PM   #54
You know Scott, if you had a better attitude about other designers, I would introduce you to the designer of the Bybee Music Rail. He and I are now working on a power amp project together. He has more education and experience than just about anyone I know. (It is not Jack Bybee)
Old 17th November 2012, 08:28 AM   #55
marce is offline marce  United Kingdom
Just curious, what frequency range do Bybee music rails work at for curring noise, just curious...as other active noise reduction I have seen used on an number of systems worked at quite high frequencies, for the lower frequecies big inductors seemed best.
An example of active noise suppression device:
http://cdn.vicorpower.com/documents/...r/ds_qpi3L.pdf
Old 17th November 2012, 08:42 AM   #56
Default Fantastic Service
Fantastic Service from the Bybee labs. I can send them back and are able to choose between refund or new ones.
Old 17th November 2012, 01:36 PM   #57
Marce, they cover a fairly large range, from very low, (but not DC) to many thousands of Hz. They are: relatively expensive, because they have to be locally made in batches. IF a custom IC could be produced, they would be cheaper to produce.
Old 17th November 2012, 01:45 PM   #58
Basic idea behind Music Rail. Note Fig. 1
Old 17th November 2012, 10:54 PM   #59
Triodethom's Avatar
I take that would require up front cost not justified by the number sold in this market ? Glad to see you are doing well the last time we meet face to face was when I ran it to you and Saul Marantz at CES .
Old 18th November 2012, 12:02 AM   #60
Pano is offline Pano  United States
Pano's Avatar
RobertF, please learn to use the quote function properly. I have fixed a number of your posts. If you need help, shoot me a PM. Thanks
Bybee Music Rails - My Experience Magz Everything Else 13 7th May 2013 08:40 AM
New problem with Music Angel KT88 alecu7 Tubes / Valves 31 17th August 2012 08:15 PM
Bybee Music Rails ® anatech Everything Else 132 7th July 2011 07:20 PM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 01:06 PM
HP stage modulates rails in tape deck. How can I reduce this problem? Triophile Solid State 0 12th April 2006 09:36 PM
Copyright ©1999-2013 diyAudio
