Bybee Music Rails Problem
Old 18th November 2012, 08:44 AM   #61
marce is offline marce  United Kingdom
Cheers John.
Old 18th November 2012, 06:50 PM   #62
Robert F is offline Robert F  New Zealand
Originally Posted by Pano View Post
RobertF, please learn to use the quote function properly. I have fixed a number of your posts. If you need help, shoot me a PM. Thanks
My apologies, I hate the thought of you spending time fixing my **** ups. I will try to do better next time!
Old 20th November 2012, 10:28 AM   #63
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Hi do anybody know if this adress is USA ? Bybee Labs San Jose, 706 Charcot Avenue, San Jose , Ca 95131
California ?
Old 20th November 2012, 10:34 AM   #64
cliffforrest is offline cliffforrest  United Kingdom
California ?
"CA" is very much California!
Do a Google Map on "San Jose, California"
Old 20th November 2012, 10:40 AM   #65
Thank You cliffforrest . To google that was to early for my brain. Just went out off bed !
Old 22nd November 2012, 11:16 PM   #66
Default Oh my G.. !
The resistors I used was 3,9 ohm instead of 3,9 kohm. Sorry I got desperate.
Old 14th January 2013, 06:35 PM   #67
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Here's a graph of Zout and Tg -- you can see the broad impedance dip centered around 120Hz, and two little kinks at 60 and 180 Hz -- at both of these points the phase margin is in the low single digits. At the zout minimum the phase margin is in the low 20's. Yes, it certainly is a filter, or combination of filters:
Edit: And here's the comparison of noise -- it's not "V", but V per root Hz on the left axis:
http://www.linearaudio.net/images/le...%20JW%20F7.pdf
Programming the AP is such fun.
Old 14th January 2013, 07:49 PM   #68
Fantastic then I understand the extra "kick" / "slam" in bass .
Old 14th January 2013, 08:10 PM   #69
jackinnj's Avatar
I don't think so...
Old 14th January 2013, 08:11 PM   #70
john curl is online now john curl  United States
john curl's Avatar
Erlend, I am glad that you finally achieved success in getting it going. It DOES work, perhaps not in the same way as a DC regulator, but it DOES work. I use them to lower the noise in my Lab power supplies.
"Condemnation without Examination is Prejudice"
Bybee Music Rails ProblemHide this!Advertise here!
New problem with Music Angel KT88 alecu7 Tubes / Valves 35 19th October 2015 11:12 PM
Bybee Music Rails - My Experience Magz Everything Else 17 27th October 2013 09:40 AM
Bybee Music Rails ® anatech Everything Else 132 7th July 2011 08:20 PM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 02:06 PM
HP stage modulates rails in tape deck. How can I reduce this problem? Triophile Solid State 0 12th April 2006 10:36 PM
