Bybee Music Rails Problem
Old 16th November 2012, 01:00 AM   #21
jcx is offline jcx  United States
shoulda dropped the Bybee name if they didn't want the reputation
Old 16th November 2012, 01:13 AM   #22
kevinahcc20 is offline kevinahcc20  United States
kevinahcc20's Avatar
Well I checked out the Bybee Labs website (distinct from Bybee Technologies of "quantum slipstream purifiers" fame) and I must say it was total truth in advertising. The label on the Bybee Rail clearly stated "Bybee 2A POS"...you can't get anymore truthful than that.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 16th November 2012, 03:53 AM   #23
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Yeah there is fools enough in the world. In fact a lot of them on Hifi forums. But the Bybee purifier I am sceptical to. I think some Carbon Composite resistors do the same job.
Old 16th November 2012, 03:58 AM   #24
Not many is in this to solve my problems. If not keep out.
Old 16th November 2012, 04:40 AM   #25
john curl is offline john curl  United States
john curl's Avatar
Erlend, you are correct, the Bybee purifier and the Bybee Music Rail are completely different devices. One is based on physics, the other based on enlightened engineering.
I have a pair of the Music Rails following my HP Lab power supplies. It drops the measured noise about 20 dB.
Having access to the schematic, I can tell you that it is just electronic engineering, inside, however, IF you for any reason, put too much voltage across the device, perhaps 60V, it will probably break, and cannot be easily repaired.
"Condemnation without Examination is Prejudice"
Old 16th November 2012, 07:29 AM   #26
Robert F is offline Robert F  New Zealand
From what I have read they don't like capacitance across their output either; or at least some capacitance values will cause problems.
Old 16th November 2012, 07:49 AM   #27
qusp is offline qusp  Australia
qusp's Avatar
correct I did mistakenly think you were talking about their other similarly dubiously named device. a power supply smoothing device that doesnt like capacitance across the output? if its so sensitive to surrounding components, they should make the schematic or at least some of it, public. maybe then people wouldnt lump it in with the other snakeoil they sell, which has been fairly thoroughly examined and deemed to not change the world as we know it
Old 16th November 2012, 08:44 AM   #28
A very common characteristic of feedback regulators...the information about this is included in its data sheet much as it is with IC reg's.
Old 16th November 2012, 09:17 AM   #29
I think the 2x 47 uf and 100 nf. I have after the Bybee should be ok ? Before the Bybee I have 1000 uf. 44 ohm serie 33000 uf. 12 ohm serie 10000 uf 33 uf and 100 nf.
The aplications says :less then 100 nf or more then 33 uf. Maybe the 2x47 uf. is to far away 7,5 cm.
Maybee that diode was bad from the start . I will try with another .
Old 16th November 2012, 09:55 AM   #30
Ok I tried with another mono amp . It looked alright up to ca 30 V . Then suddenly the voltage dropped 15 V.
Want my money back.
Bybee Music Rails ProblemHide this!Advertise here!
New problem with Music Angel KT88 alecu7 Tubes / Valves 35 19th October 2015 11:12 PM
Bybee Music Rails - My Experience Magz Everything Else 17 27th October 2013 09:40 AM
Bybee Music Rails ® anatech Everything Else 132 7th July 2011 08:20 PM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 02:06 PM
HP stage modulates rails in tape deck. How can I reduce this problem? Triophile Solid State 0 12th April 2006 10:36 PM
Copyright ©1999-2017 diyAudio
