MY NEW 1.5KW SMPS SOME REVIEWS
7 Attachment(s)
Hi
I have developed a 1.5KW smps for class AB amps . It is still under testing will publish results . Topology used :- Full bridge . Output :- +-95V @ 15A Input Voltage :- 230VAC @ 50Hz Features :- 1. Input Over Voltage Protection 2. Short Circuit Protection 3. Over Temperature Protection Some Pics Attached :- Regards Phoenix 87 |
Can u post a schematic?
was the SMPS moving? ;)
as mentioned above, without a schematic and with every single photo being blurry, its almost impossible to make any comment, even though the idea of a 1.5kW supply for class AB is interesting |
95+95*15= 2890KW?
I like you have specced it for single rail operation at one time which is in reality how it will be used. |
Creepage and clearance?
+-95VD @ 15A ?
That sounds good, but for how many minutes? regards |
Hello,
would it be possible that you provide the schematics? i'd need to built an smps like that too. greets from vienna |
Hi phoenix
greetings can i use ETD59 instead of EE 55 core warm regards andrew lebon |
smps
1 Attachment(s)
Hi Phoenix
greetings built this smps working good but no protection can protection be added to it warm regards andrew lebon:cool: |
smps
1 Attachment(s)
Hi Phoneix
greetings hows this simple schematic to diy warm regards andrew lebon:cool: |
| All times are GMT. The time now is 11:31 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
