Working LED's from 54Volt - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th November 2012, 03:34 AM   #11
Thanks for the replies you all !
Power is not a problem, I 've got six pluggable modules each giving 54v /40A, so that is 40 x6 = 240A/54V.
Thanks again
Jan
Old 14th November 2012, 04:23 AM   #12
Robert Kesh Said
“Total wattage will be about half a watt per diode in first instance, 1/4 in second, 1/8 watt in last. (powerbob was thinking amps when he multiplied watts by volts) “
Thank you for the correction, I should have said.
Your power supply will have to be able to deliver .63W x 5LEDS = 3.15 Watts.
With a total current of.
5 LED x .012A = .06A
Also as Robert Kesh Said, it is difficult to determine LED brightness with current. First buy the LEDS you want to use then determine the resistor by using less than specified current and checking brightness with different values of resistor.
Old 16th November 2012, 03:48 AM   #13
The relays draw a current. A series resistor to drop about 2 volts and an LED across this resistor will give u fool proof indication. In case the relay coil opens, the LED will not light.
Gajanan Phadte
2 Color LED's? toufu Parts 8 17th November 2010 10:58 AM
LED's jim5763 Swap Meet 3 21st February 2010 01:04 AM
UV LED's Bengali Everything Else 8 15th April 2007 03:42 PM
Mill your LED's!!! theAnonymous1 Parts 32 15th August 2006 11:54 PM
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 11:14 AM
Copyright 1999-2017 diyAudio
