Some thoughts on the T-Reg - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th November 2012, 03:10 PM   #1
jackinnj's Avatar
Default Some thoughts on the T-Reg
Saw on Jan's site that a batch of T-Reg boards are out for final testing. I've had this on my wish list for a while.
I simmed a Bode Plot using a strapped 6BQ5 -- ymmv as these tube models seem to leave a lot to be desired. Also used Zetex ZTX450/550 for the error amplifier since I have plenty around.
When the boards are available we'll run a real test.
Old 10th November 2012, 06:52 PM   #2
jackinnj's Avatar
This is the schematic I'm using -- changed the error amp transistors to those with lower Cob:
Old 11th November 2012, 01:21 PM   #3
jackinnj's Avatar
Ok, everyone using a Maida regulator look at this:
The devices were compared under equally light load, with equal perturbation voltage of the error signal. A pair of TIP50's was used for the Maida.
Once again, ymmv.
I am going to have to try this with the LT3080 based regulator...
Old 11th November 2012, 03:03 PM   #4
jan.didden's Avatar
The newer version works well with a MOSFET.
Needed to adapt the control circuit, but it seems to work well, proabbly start testing week after next.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 11th November 2012, 11:12 PM   #5
jackinnj's Avatar
I see you've temp compensated U1.
There must be a "ubangi in the fuel supply" (W.C. Fields in "You Can't Cheat an Honest Man", circa 1939) as it's not quite simulating correctly.
Old 12th November 2012, 07:46 AM   #6
jan.didden's Avatar
What does/doesn't it do? It does work on the bench here.
Edit: Q5 is a source follower, I guess you got that?
jan
Old 12th November 2012, 12:44 PM   #7
jackinnj's Avatar
jan
Yes, the problem is with my simulator -- had this once before with Multisim -- you have to uninstall it, reinstall. POA. On my laptop with a legacy Multisim 10 it works.
Old 3rd June 2016, 09:56 PM   #8
jackinnj's Avatar
hmmmm
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 5th June 2016, 08:25 AM   #9
I can't get any of the pics linked in posts 1, 2 & 3 to download.
Any chance you could attach them instead?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th June 2016, 12:00 PM   #10
Ketje is offline Ketje  Belgium
Ketje's Avatar
Hmmm (bis )
Why not keeping it simple, I like simple
Mona
Could someone help me with a reg. with 0.1-0.5V out tobias_svensk Power Supplies 34 8th September 2008 10:34 AM
Lm317 Reg geowhitt Parts 2 30th August 2008 08:39 AM
Reg problem /help! duffy Pass Labs 1 17th March 2006 10:54 AM
sulzer reg costiss Solid State 3 2nd February 2003 12:54 PM
Copyright 1999-2017 diyAudio
