Fuse positioning in PSUs
Old 10th November 2012, 02:48 PM   #1
polsol is offline polsol  South Africa
Default Fuse positioning in PSUs
Having a fuse on the line input and on the DC output of a PSU is standard practice (well at least the mains input).
However, I have seen designs that include an additional fuse(s) between the transformer secondary and the bridge rectifiers or ones with fuses between the bridge and the caps.
Is one of the latter topologies actually necessary/of benefit?
If they are desirable, how would one calculate their values?
As a side issue, when mounting an unshielded toroid with 'flying leads' is it possible to mount the toroid upside down so the leads are at the bottom - i.e. in contact with the case? I'd guess that this would dangerous but I haven't found a website that mentions this possibility or that warns against it.
Cheers.
Tony M
Old 10th November 2012, 02:55 PM   #2
DF96 is online now DF96  England
A fuse between the secondary and the rectifiers can protect the transformer from a shorted rectifier. A fuse before the reservoir cap can protect the rectifier from a shorted cap. Generally, a fuse protects the things near it in the circuit and may provide some weaker protection for things a bit further away.
The fuse value is calculated from the expected RMS current, as for any circuit. This can be difficult when rectifiers are concerned. You could use a guess of 2-3 times the DC current.
Old 10th November 2012, 03:17 PM   #3
Thanks for the reply DF96, pretty much as I thought.
I guess the question is which is more likely to fail, the bridge rectifiers of the electrolytics.
Tony M
Old 10th November 2012, 03:17 PM   #4
Robert Kesh is offline Robert Kesh  Wallis & Futuna
Robert Kesh's Avatar
So what fuses do you guys think sound best? I like Gossen Metrowatts700V, but would probably use Schurters 1000V if I could afford it.
Old 10th November 2012, 03:24 PM   #5
On Hiatus
SY's Avatar
I've been listening to mine, but they seem to be quite silent.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 10th November 2012, 03:26 PM   #6
My last post was intended to be humorous, by the way.
Old 10th November 2012, 03:28 PM   #7
On Hiatus
SY's Avatar
Different fuses CAN lead to audible differences, though. I put a 100mA fuse in the power rails of my power amp and the power amp was much quieter than with a 3 amp fuse.
Old 10th November 2012, 03:29 PM   #8
Old 10th November 2012, 03:41 PM   #9
Doing away with the PSU altogether results in a remarkably low noise floor.
Tony M
Old 10th November 2012, 03:46 PM   #10
R.I.P.
Fuse the mains close rated. (300VA on 220Vac can use T1.25A or T1.6A, you will need a soft start)
Then a fault at the output of the transformer blows the mains fuse.
There is a big advantage in fusing the output of the PSU at the PSU, not at the amplifier.
Once these three fuses are fitted I cannot see any advantage in fusing before the smoothing capacitance. They would need to be so big to survive start up, that they never blow quickly enough to protect anything that survives the first few microseconds of fault condition.
regards Andrew T.
Fuse positioning in PSUsHide this!Advertise here!
Toroidal positioning Mankysteve Chip Amps 5 15th September 2010 10:42 AM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Positioning loudspeakers XXX Multi-Way 0 28th May 2007 03:14 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
