#11 | |
#12 |
Hi Andrew,
Thanks for your response. I guess the problem is chosing a mains fuse 'just right' to prevent spurious blowing is a matter of experience.
Tony M |
#13 |
Pol,
divide VA by Vac and you get the normal maximum current that the transformer will draw. Choose a fuse around that value and you have selected a close rated fuse. Alternatively, for motors and transformers and similar inductive loads the fuse value can be VA / Vac * 3 The T rated three times fuse value will generally allow a toroid transformer, charging up a capacitor input filter, to start and run without nuisance blowing of the mains fuse. I don't like this alternative. I prefer close rated fusing, except when I get down to lower than 60VA. Then I'll not bother going any lower T250mA (240*0.25 = 60VA) |
#14 |
Thanks once more Andrew for all your help.
Tony M |
| Toroidal positioning | Mankysteve | Chip Amps | 5 | 15th September 2010 10:42 AM |
| Fuse housing melting but fuse not blowing, ppi amp | rawadia | Car Audio | 21 | 2nd August 2008 10:39 AM |
| Positioning loudspeakers | XXX | Multi-Way | 0 | 28th May 2007 03:14 PM |
| amp rating for fuse and fuse holder? | riotubes | Parts | 5 | 27th August 2006 03:10 AM |
