Simple 12v adjustable help
Old 23rd November 2012, 08:52 AM   #21
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
Well i think it is you that needs to read much more carefully my messages, just because someone doesn't like some of your sugestion it does not give you any reason to be upset, and by no means does it gives you the right to attack them, as i sayd you are stuck on useless semantics, even you understud what i meant but you are maybe too stubborn to admit it.
Well, if that is what you are then, good luck, you'l need it.
Have a go at my latest set => Dj Marik -
Trance session live ep. 94
Old 23rd November 2012, 06:19 PM   #22
liamstears is offline liamstears  United Kingdom
Originally Posted by liamstears View Post
I just came across this circuit here (scroll down to Simple Adjustable Voltage Source):
Telephone In-Use Relay, LM317 Regulators, Lithium Charger
And this sounds perfect
Now my questions are, how many amps could this simple npn pnp circuit provide? Also just how much heat will it produce?
I only have the small clip on heatsinks that I can put on it although I could possible place it on the larger heatsink in the power supply and possibly even next to the slow running 80mm intake fan if needed?
I think I will go this route as it's simple and cheap just need to know how many amps I can get in this circuit and how well I need to cool it
If possible I would like to be able to supply up to 5a so if different parts are needed in this same circuit please do let me know although I could live with 2a output
So is my attached picture right before I wire it up?
Old 23rd November 2012, 08:41 PM   #23
tauro0221 is offline tauro0221  United States
I do not know really what you want to accomplish. You are changing constantly your design and you will not accomplish anything. Stick to one design and see if you can make it work. I never had a problem using linear voltage regulators and I see that you can not get none to worked. If you follow to the letter the datasheet or used one of the samples schematic in the datasheet you will not have a problem. If you want 5 amps output my advice it is to use the LM338. It will output 5 amps with a good heat sink. If you use the LM317 max amp output will be 1.5. and you must have to bypass it with a transistor to be able to output more than 1.5 amps. Get the LM338 follow one of the examples that meet your specification in the datasheet and as long you follow the schematic you will not have any problems. Give it try.
Good luck.
Simple 12v adjustable helpHide this!Advertise here!
simple adjustable voltage regulator? AKHeathen Equipment & Tools 7 2nd July 2012 12:23 PM
Simple 12v gain stage dublin78 Solid State 10 14th April 2008 03:37 PM
Simple 12V SMPS for small powered devices EWorkshop1708 Power Supplies 16 13th April 2008 10:46 PM
Simple 12v Smps johnyp Power Supplies 13 10th July 2006 01:45 PM
Simple 12V DC Power Supply for a Beginner? Llamas Everything Else 1 23rd August 2003 01:23 PM
