Shunt regulator on ebay-how good?
Old 8th November 2012, 09:33 AM   #1
46 goat is offline 46 goat
Default Shunt regulator on ebay-how good?
Hello Everyone. I have seen this shunt on ebay and I wonder if anyone has used it or what your views on it are. How good is it?
Input is up to +- 45Vac output adjustable from 18v to 60v at 500mA.
Cheers
Old 8th November 2012, 07:36 PM   #2
Bump anyone. This regulator is advertised by Jims Audio and Tubeshunter
Any thoughts?
Cheers
Old 10th November 2012, 08:44 AM   #3
metalsculptor is offline metalsculptor  Australia
It is a fairly basic current source feeding a low gain shunt regulator, providing that it has no instabilities it should work OK, transient response might be ordinary.
Any good regulator should have specifications, if the designer is incapable of providing performance measurements then you would wonder about their design abilities, testing goes hand in hand with designing.
Why not use a high voltage monolithic series pass regulator?
Old 12th November 2012, 08:17 PM   #4
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Check out Water Jung website for regulator both series and shunt Home
Old 12th November 2012, 08:59 PM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
'improved regulater' is show with a floating IC(LM317) as pre reg ?
Shunt regulator on ebay-how good?Hide this!Advertise here!
Shunt Regulator variations (Parallel voltage regulator variations) for SS Pre-Amp tiefbassuebertr Solid State 2 15th December 2012 10:09 AM
HQHV shunt regulator! quanghao Power Supplies 0 14th December 2011 12:54 PM
Shunt Regulator PoweRex Power Supplies 1 22nd July 2011 10:53 AM
How about shunt regulatorH uhcmos Solid State 4 2nd March 2007 09:32 AM
Shunt regulator tubee Tubes / Valves 12 2nd March 2006 01:08 PM
Copyright ©1999-2017 diyAudio
