Mystery Transformer Identification
Old 6th November 2012, 09:41 PM   #1
Einric is offline Einric  United States
Einric's Avatar
Default Mystery Transformer Identification
Hey guys I have a mystery transformer.
It has the following written on it.
E 1068001C
9968310
It is 110V Secondary w/CT.
It appears to have dual primaries for 110/220V operation.
The secondary winding looks to be 14awg.
It weighs about 15 pounds
Any thoughts on the VA rating?
Old 6th November 2012, 09:54 PM   #2
Einric's Avatar
It measures 4.5"x3.75"x5.5"(Across Endbells)
Also .6Ω through the secondary.
Old 7th November 2012, 05:21 AM   #3
rikkitikkitavi is offline rikkitikkitavi
how many amps do you get out of the secondary if you count on 3A/sq mm, that is 400 circular mils per amp? (Im a stricktly metric guy)
Weight and.size can give an idea about VA rating within 20-25%. Current density in windings is actually the sizing parameters.
If you had superconducting windings, VA rating could have.been infinite
listen! Can you hear that ...
Old 7th November 2012, 05:32 AM   #4
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
around 500VA...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th November 2012, 06:55 AM   #5
And how did you come to that answer?
Old 7th November 2012, 07:07 AM   #6
TonyTecson's Avatar
secondary is 110volts, and 5amps on #14 wire is reasonable....
the traffo used a core with 1.5inch center leg and stacked to about 3.5inches....
Old 7th November 2012, 07:14 AM   #7
thanks!
Old 7th November 2012, 11:44 AM   #8
R.I.P.
Originally Posted by Tony View Post
.........the traffo used a core with 1.5inch center leg and stacked to about 3.5inches....
does this indicate a lowish flux in the core? Any idea of the value?
Is that typical of EI power transformers?
regards Andrew T.
Old 7th November 2012, 09:21 PM   #9
TonyTecson's Avatar
without knowing the primary turns, it is hard to tell...
Old 8th November 2012, 08:30 AM   #10
R.I.P.
well, we are seeing a VA rating based on copper in the secondary combined with a high area of core.
Does that imply a low core flux?
Or is it that they simply used less copper in the secondary?
That would imply a high current density in the secondary and thus more I^2R loss creating a hot running transformer if used continuously at maximum VA.
Surely we can infer something from the two numbers we see.
regards Andrew T.
Mystery Transformer IdentificationHide this!Advertise here!
transformer identification ChipTube Tubes / Valves 9 21st June 2010 03:45 PM
My mystery transformer. azira Solid State 4 9th September 2007 06:42 PM
Transformer - mystery VA seventenths Power Supplies 10 5th September 2007 05:47 PM
Mystery transformer Ty_Bower Tubes / Valves 2 15th June 2007 12:24 AM
Torridal Transformer identification jeffshort2000 Parts 4 8th January 2007 07:13 AM
