Blown parallel FETs?
Old 19th October 2012, 09:35 PM   #1
Yooper is offline Yooper  United States
Default Blown parallel FETs?
If you ever had a bank of FETs fail, you know the feeling.
Here's a handy way of finding the bad one.
Note: not plural.
Put an ohmmeter across D - S.
Take a large soldering iron and hold the tip on the body of the each FET and heat it up.
If it's the bad one, the ohm reading will noticeably increase.
Beats the heck out of desoldering, especially if SMT devices.
Old 20th October 2012, 11:14 AM   #2
R.I.P.
are you referring to vertical Power mosFETs?
regards Andrew T.
Old 20th October 2012, 06:04 PM   #3
sbrads is offline sbrads  United Kingdom
That trick works for most zapped semiconductors in parallel with whatever, although sometimes a few more volts are needed than whatever a typical DVM delivers on the ohms or diode range.
Old 21st October 2012, 12:06 AM   #4
whizgeek is offline whizgeek  Ireland
I used to have a 4volt 400va transformer with 2x56000uF caps.
needed safety glasses, but it could find and fix any short circuit.
Blown parallel FETs?Hide this!Advertise here!
Autotek Super Sport At2000.1 blown psu fets substitude ivkata Car Audio 2 17th April 2012 03:26 PM
Parallel Lateral FETs Neutrality Solid State 2 20th September 2011 03:56 AM
Rockford Fosgate 60ix FETs blown LazySteve Car Audio 12 23rd June 2011 08:48 AM
thermal stability of parallel FETs zhoufang Solid State 6 26th September 2009 01:29 AM
How many parallel fets could BOSOZ drive? Michael Rothacher Pass Labs 7 18th February 2004 12:44 AM
