diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   feedback relating core usage (http://www.diyaudio.com/forums/power-supplies/221107-feedback-relating-core-usage.html)
sweetperfume 7th October 2012 06:18 PM
i'm very new to smps...i need to know is it require to create gap between middle part of ETD cores of about 2 mm......and keep the outer part as it is....i wanna built am smps for my audio amp
palstanturhin 7th October 2012 06:38 PM
What topology?
What output power?
What input voltage?
sweetperfume 9th October 2012 05:33 PM
Originally Posted by palstanturhin (http://www.diyaudio.com/forums/power-supplies/221107-feedback-relating-core-usage-post3192984.html#post3192984)
What topology?
What output power?
What input voltage?
dont know about topology but i need output power of 1000watts with an input voltage of 220volts.....i'm new to smps....i had seen several designs using the ir2110 and sgs3525....and thought of building one of those...so asked for a little help
RJM1 9th October 2012 06:03 PM
Gaps are usrd in flyback topology and are generally used only to about 250 to300W.
My recommendation is to use a full bridge topology which would be more efficient at that power level and not require transformer gaping.
sweetperfume 11th October 2012 04:18 AM
Originally Posted by RJM1 (http://www.diyaudio.com/forums/power-supplies/221107-feedback-relating-core-usage-post3195292.html#post3195292)
can this topology can handle pure rms1000watts output.....if yes can u give me any of the design which i can try....for start i need a simple design....give the required info with all the characteristics....
warm regards
sweetperfume 12th October 2012 07:31 PM
can anybody give me a design of full bridge topology smps rated power of 1000watts
nigelwright7557 15th October 2012 12:59 AM
Originally Posted by sweetperfume (http://www.diyaudio.com/forums/power-supplies/221107-feedback-relating-core-usage-post3199236.html#post3199236)
Try here:
diysmps)
Resources saved on this page: MySQL 18.75%
