diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Regulators from Jims Audio. (http://www.diyaudio.com/forums/power-supplies/221017-regulators-jims-audio.html)
alibear 5th October 2012 07:32 PM
Hi all, I want to use a shunt regulator for the input and VAS of a class A amplifier, with an output that can be adjusted between 30V and 35V. Has anyone any views on two regulators from Jims Audio, one is a Kubota type and one termed "class A shunt regulator". They both have variable posative and negative outputs in the voltage range I require, with ample current.
Buying a kit would be an easier solution for me than trying to make my own PCB.
Thanks for your help
Alan
CZ101 5th October 2012 10:32 PM
I have a similar question about this shunt regulator PCB on ebay. It ships from Indonesia and is described as "overstock Shunt Regulator PCB design by Mr. Salas". Any comments would be really helpful...
syklab 6th October 2012 02:56 AM
It doesn't look anything like the pcb I bought from Salas at all.
Ryssen 6th October 2012 11:51 AM
It might work after all.
alibear 6th October 2012 12:44 PM
I was interested in this one Low impedance 500mA class A shunt regulator kit ! | eBay
Alan
alibear 6th October 2012 12:46 PM
And this one Kubota low noise regulator full blown version kit !! | eBay
Alan
dirkwright 6th October 2012 01:31 PM
Originally Posted by alibear (http://www.diyaudio.com/forums/power-supplies/221017-regulators-jims-audio-post3191722.html#post3191722)
I bought two of those kits and they work ok. I didn't do extensive testing so I don't know much else.
alibear 7th October 2012 08:21 PM
1 Attachment(s)
Hi, I cannot find a circuit for the Kubota regulator, I presume it's a shunt type regulator, but I don't know for sure. Has anyone any details please? Here is a diagram of the second regulator I am interested in ( the class A shunt regulator ) does it look reasonable?
thanks for your help.
Alan
neugruen 7th October 2012 09:25 PM
Kubota Regulator
http://www.diyaudio.com/forums/attac...botaregckt.gif
dirkwright 7th October 2012 10:38 PM
Originally Posted by alibear (http://www.diyaudio.com/forums/power-supplies/221017-regulators-jims-audio-post3193021.html#post3193021)
Alan
I don't believe that is a shunt regulator. It looks like a regular series regulator to me.
Resources saved on this page: MySQL 18.75%
