Strange ripple on rails when amp is connected
Old 4th October 2012, 06:53 AM   #11
jitter is offline jitter  Netherlands
jitter's Avatar
Originally Posted by Mooly View Post
I too think layout and grounding is probably the most likely cause and from what I can see from your picture it all looks really neatly built.
If the "hum" has a harsh sounding edge to it (harmonics present) then grounding is a prime suspect.
I agree, see also this thread. On symmetrical PSUs with single bridge and centre tap as GND, where that centre tap connects with respect to signal reference (GND) is all important.
50 hz hum. If it were induced hum then I would think the output would be more sinusoidal and tbh at that level probably not audible. 50 hz as a sinewave is a very deep pure tone (if the level is high enough).
Worth an experiment.
I have a DIY class A headphone amp that is powered by a toroid. Because of limited space, it was near the amplifier board and with no signal on the input I could hear a very faint hum. After hanging the toroid on the outside of the case, the hum disappeared.
Move all transformers away from the wiring through which the signals flow as far as possible. If hum goes away, it was induced.
Old 14th October 2012, 09:36 PM   #12
Bensen is offline Bensen  Belgium
Bensen's Avatar
Default Problem solved
1: after the right frequency measurements of 50Hz and 100Hz, I stopped thinking that the problem was the power supply
2: as mentioned by Nigelwright7557, I put in a 33R before the cap that buffers the LTP's and VAS ==> humm was still there, but amp seems to be having more detail
3: I splitted the audio ground and power ground by a 10R resistor.
==> this solved the humming problem.
With the input shorted and my ear against the tweeter, I can't hear a thing!
Thanks guys!
Old 14th October 2012, 09:46 PM   #13
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Thanks guys!
Classic ground loop problem.
I built a mixer on a pcb with no thought to grounds and it hummed really badly. When I split off the power supply and had one star ground the humm went completely.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/itm/253272755...84.m1555.l2649
Strange ripple on rails when amp is connectedHide this!Advertise here!
strange ripple noise in DC power supplies ? skibum Power Supplies 12 27th May 2012 02:29 PM
Powered up amplifier without one of the psu rails connected - now distorted channel Coconuts 500 Solid State 9 25th February 2012 03:10 PM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 02:06 PM
amplifier works connected to PC .. but not when connected to car radio anwaypasible Analog Line Level 1 2nd March 2011 08:42 PM
Ripple filtering help... strange slow rise and fall of voltage jlw Tubes / Valves 7 30th August 2008 06:50 AM
Copyright ©1999-2017 diyAudio
