diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Toroid Transformer Vertical or Horizontal Mounting (http://www.diyaudio.com/forums/power-supplies/220890-toroid-transformer-vertical-horizontal-mounting.html)
SLAK 3rd October 2012 09:36 AM
Hello,
I am Building a Stereo power amp (Class A) using two identical transformers (400VA Each), Each trans for each channel. Obviously Size is the issue, i need to make the Chassis as Slim as possible, so mounting the Transformer vertically makes a big difference & gives me lots of space inside the chassis aswell. I do see lots of Plus in mounting they vertically but are there any Minuses?
So, which is the best mounting method for toroid Trans, with which we (DIYers) may be able to avoid Humm, Crosstalks, interference and any other problems faced on DIY pojects because of Toroidal transformers.
Also i would like to ask, Which sections of a Toroidal transformer has lots of Electromagnetic Wave Emmitance, Top/Bottom or Side (Outer Diameter)
Any Help or Recommendation will be deeply appreciated.
Thanks & Best Regards.
SLAK
Zen Mod 3rd October 2012 09:50 AM
http://tinyurl.com/8bp8tjy
http://tinyurl.com/933ws7j
http://tinyurl.com/9fr3a6v
on these pics "sponge rubber " strips are important parts
consider entire toroid as magnetic field emanating object
balerit 3rd October 2012 11:04 AM
The only worrying thing is the steel bolt going thru the transformer connecting the bracket and the casing.
Mac
DUG 3rd October 2012 11:42 AM
Horizontal vs Vertical: The only difference is going to be the weight of the bracket in your amp.
Toroids are self shielding in that there is no definite gap to form a magnetic field across.
If you are concerned about stray field you can put a shield over the whole toroid, but make sure you do not make a complete conduction path through the toroid. i.e a complete loop. This would be like a shorted secondary winding. not good
SLAK 3rd October 2012 12:37 PM
Originally Posted by Zen Mod (http://www.diyaudio.com/forums/showthread.php?p=3188461#post3188461)
Thanks a Lot for the Pics.
SLAK 3rd October 2012 12:38 PM
2 Attachment(s)
So, How about making a Barrier between the Amp Boards & the transformer, just like i have shown in the virtual images I made below.
Making a 1mm Steel or a 5mm thick Plastic wall/barrier between the transformers & the Amp boards. Also covering this wall with a thin layer of Leather. Will this method do any Good to shield the amp boards from Electromagnetic waves being emitted from the transformers? Or is it a waste of time to make these Barriers?
wintermute 3rd October 2012 01:02 PM
I'd use 3mm steel. I suspect 1mm won't make much of a difference, 5mm plastic I'd be surprised if it had any effect at all :) I can't see any reason the leather would help but if you have a theory on that I'm all ears! I used lead for a shield on my torroid years ago, which did have an effect but not as much as I would have liked, I since found out that steel is a much better attenuator for EMI.
Tony.
SLAK 3rd October 2012 01:12 PM
Originally Posted by wintermute (http://www.diyaudio.com/forums/showthread.php?p=3188598#post3188598)
Tony.
Hello,
To be Honest i did not come up with the Leather theory. Its just that not long ago i had opened up a Hi-End Amplifier (Chinese) the toroid transformers were contained in a special Round enclosure, i think steel was the material of the enclosure about 1mm thick & the outer surface of the enclosure was completely covered with some sought of leather material. I thought maybe the leather covering meant something.
wintermute 3rd October 2012 01:26 PM
It could be used as an insulator to ensure that there isn't a shorted turn.
Tony.
SLAK 3rd October 2012 01:41 PM
Originally Posted by wintermute (http://www.diyaudio.com/forums/showthread.php?p=3188623#post3188623)
Tony.
Yes, Maybe.
I'd use 3mm steel. I suspect 1mm won't make much of a difference.
In that case i will have to drop my plan to even make a barrier, Cutting a 3mm Steel Plate as per the required dimension seems a time consuming & a expensive process (using laser cutting method).
Copyright 1999-2017 diyAudio
