LM317 tracking pre-regulator and current regulator
Old 2nd October 2012, 09:38 PM   #31
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
what is your voltage drop across the regs? The LM317 performs best with at least 5V in to out difference if you don't have 10V to drop then make the voltage drop on the second one higher, making sure to at least have more than the drop out voltage on the first one (unless of course it doesn't matter in this configuration which I have not tried).
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 2nd October 2012, 09:49 PM   #32
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar LM317 tracking pre-regulator and current regulator
Voltage drop across current reg is 3.5V+1.24V across 1.22 ohm resistor+6.1V across filament equals 12.84V. So there is roughly 6V drop across TPR.
I must use heatsinks with lower C/W, I think. They are quite hot. I can touch it, but not too long. I guess they are about 50-60 C. I will try to measure temperature tomorrow.
Old 5th October 2012, 08:04 PM   #33
yagoolar's Avatar
Filament regulators for 6C4C completed.
Old 6th October 2012, 12:36 PM   #34
yagoolar's Avatar
Measured or shall I say estimated* temperature of heatsinks of all regs - they are 65 to 75 deg C hot in open air. I guess regs themselves has higher temp. I will measure when the board is inserted into the enclosure.
Schottky diodes are mounted without heatsinks and the temperature is about 40 deg C.
___________
* I used temperature sensor form the kitchen oven while my beloved wife was away
LM317 tracking pre-regulator and current regulatorHide this!Advertise here!
Need help with tracking regulator adjustment. Please. G Solid State 7 23rd September 2014 08:38 PM
Shunt Regulator variations (Parallel voltage regulator variations) for SS Pre-Amp tiefbassuebertr Solid State 2 15th December 2012 10:09 AM
tracking regulator to solve everyone's problems? mazurek Solid State 0 5th June 2006 01:36 AM
LM317 current regulator Bas Horneman Tubes / Valves 22 17th January 2003 10:25 PM
Opinions of tracking regulator circuit. G Solid State 1 30th September 2002 10:41 AM
