LM317 tracking pre-regulator and current regulator
Old 1st October 2012, 09:26 PM   #21
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar LM317 tracking pre-regulator and current regulator
Four 10mF/25V caps added. B540 replaced with Schottky PBYR1025 in TO220 to save space - a bit hot. Vripple = 0.7mV rms @ 9.2 ohm load
Old 2nd October 2012, 11:42 AM   #22
yagoolar's Avatar
Yet, there is a difference between attached schematic and tested circuit, i.e. values were measured with one LED setting reg2 voltage. Need to add another one.
Old 2nd October 2012, 04:27 PM   #23
yagoolar's Avatar
Output voltage ripple. 2 mV/div @ 10,13V DC and 9,3 ohm load.
C6 has no significant effect on ripple voltage.
Old 2nd October 2012, 05:51 PM   #24
yagoolar's Avatar
Same condition, except rectifiers changed to Schottky 1N5822 (was PBYR1025). Darn!
Old 2nd October 2012, 06:01 PM   #25
yagoolar's Avatar
Same condition, rectifiers are Schottky SB540. See for yourself, I go back to 10A 25V PBYR1025 in TO220.
Old 2nd October 2012, 06:55 PM   #26
yagoolar's Avatar
Back to PBYR1025 Schottky in voltage doubler.
Old 2nd October 2012, 07:00 PM   #27
yagoolar's Avatar
So some more testing: BY229/800.
20mV/div. Just for fun and reference.
Old 2nd October 2012, 07:24 PM   #28
yagoolar's Avatar
Back to PBYR1025. Added 2200uF || C8 (10uF).
Scale: 2mV/div
Enough. Now I can tune output current and connect a tube.
Old 2nd October 2012, 08:37 PM   #29
yagoolar's Avatar
Tube 6C4C filament connected with 2200uF || C8 - oscillations. .5us/div
2200uF removed. 5 ms/div
Tube 1. Uf=6.10V so far, so good.
Tube 2. Uf=6.18V
Tube 3. Uf=6.15V
Old 2nd October 2012, 09:11 PM   #30
yagoolar's Avatar
Note 2 LEDs at left - seems they have different specs. Brightness and voltage drop are different, 1.9V and 1.6V.
LM317 tracking pre-regulator and current regulatorHide this!Advertise here!
Need help with tracking regulator adjustment. Please. G Solid State 7 23rd September 2014 08:38 PM
Shunt Regulator variations (Parallel voltage regulator variations) for SS Pre-Amp tiefbassuebertr Solid State 2 15th December 2012 10:09 AM
tracking regulator to solve everyone's problems? mazurek Solid State 0 5th June 2006 01:36 AM
LM317 current regulator Bas Horneman Tubes / Valves 22 17th January 2003 10:25 PM
Opinions of tracking regulator circuit. G Solid State 1 30th September 2002 10:41 AM
