Hi, I need someone to verify if my thought process is correct.
This image is the regular set up for decoupling for supplying power. IMAGE01 This is what I believe I could do to simplify and reduce cost. By using the 100+100uF JJ cap, it will cost less and take up a little less real-estate. IMAGE02 So my questions are: (1) is this how you properly use a dual section cap. (with and without the film caps on the side) (2) does this create potential ground loop danger? (not as star ground as it could be) (3) new gained length from caps to anode. Possible bad thing? Thanks in advance if anyone can give me pointers. |
#2 |
I can't see your pics.
Are you suing a remote server. What's wrong with attaching pics? |
#3 |
Hi Andrew,
Ya, I am using a remote server to host my images. They were kind of big so I kept them as links instead. If you can't click on them I'll try a different method |
#4 |
#5 |
100uF+100uF @ 500V JJ Can Electrolytic Capacitors:QTY=3 | eBay
If this helps, this is the capacitor in question? |
#6 |
no pics
#7 |
#8 |
Difficult to decipher a skeleton board layout. A circuit diagram would be better. A dual cap means sharing the negative connection. Whether this is a problem depends entirely on context.
#10 |
Thanks N-Brock for the recommendation. Didnt know that uploading to the forum is a safer avenue.
I guess my question doesn't necessarily need a diagram to discuss really. My question really is 'why would one use a dual capacitor'. From my point of view its to cut down on components and or cost. But I was wondering what it means sonically. (Star ground etc) |
| 2 SECTION AIR VARIABLE CAPACITOR | sakellogg | Analogue Source | 17 | 31st March 2012 03:07 AM |
| Differences between single-section and two-section filters | Sunsun22 | Power Supplies | 3 | 20th November 2009 05:23 AM |
| F&T Dual Section Box Quantity Special Offer | MCampbell | Vendor's Bazaar | 0 | 2nd June 2009 06:10 PM |
| Dual Section Capacitors 20+20uF, 10+10uF & 12+12uF | MCampbell | Parts | 5 | 30th March 2009 06:34 PM |
| Star ground w/ Dual capacitor banks | Killjoy99 | Solid State | 23 | 29th September 2004 10:23 PM |
