Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th September 2012, 08:30 PM   #11
DF96 is offline DF96  England
Dual or triple (or more) capacitors were common in the valve era. Often the negative connection was the can, which was clamped to the chassis. You just connected all grounds to the nearest point on the chassis and let the currents find their own way. This was good enough for radios and amplifiers, as a little hum was regarded as normal back then.
Old 30th September 2012, 08:50 PM   #12
oh interesting! That makes some sense chronologically.
So without a doubt, being that I am interested in reducing hum as much as I can, it is wiser to separate the capacitor grounds to their individual grounds as much as possible.
I had some rough understandings with dual (or more) capacitors, but couldn't find any good literature on the subject.
Old 1st October 2012, 09:01 AM   #13
AndrewT is online now AndrewT  Scotland
I can see post9 pics.
Do they need to be 1920pixels wide?
Old 1st October 2012, 09:04 AM   #14
There is nothing wrong with separate grounding of the -ve of each of the PSU capacitors.
That is exactly the same as separate the PSU Zero Volts from the Main Audio Ground.
Old 1st October 2012, 11:21 AM   #15
Andrew, your thought made me think about ground loops and how two psu's caps independant ripple variations will be so minor it shouldn't really matter at all if they are linked at ground out of the can vs at the star ground.
The bad ground loop scenario would be one with cathodes and other components at the bottom of each stage.
Are my thoughts on ground loops and star grounds somewhat right?
2 SECTION AIR VARIABLE CAPACITOR sakellogg Analogue Source 17 31st March 2012 03:07 AM
Differences between single-section and two-section filters Sunsun22 Power Supplies 3 20th November 2009 05:23 AM
F&T Dual Section Box Quantity Special Offer MCampbell Vendor's Bazaar 0 2nd June 2009 06:10 PM
Dual Section Capacitors 20+20uF, 10+10uF & 12+12uF MCampbell Parts 5 30th March 2009 06:34 PM
Star ground w/ Dual capacitor banks Killjoy99 Solid State 23 29th September 2004 10:23 PM
Copyright ©1999-2013 diyAudio
