Poles and zeros for two transistor forward?
Old 26th September 2012, 05:23 AM   #1
treez is offline treez  United Kingdom
Banned
Default Poles and zeros for two transistor forward?
Hello,
Can any reader list the poles and zeros for a two transistor forward converter?
i.e. for the power stage and modulator?
The control chip is UCC38C44
http://www.ti.com/lit/ds/symlink/ucc38c44.pdf
Vin = 385VDC
Vout = 80V
Load = 20 Ohms (maximum, heavyest load)
Switching frequency = 85KHz
C(out) = 940uF
ESR of Cout = 0.1 Ohm
L(out) = 186uH
Turns ratio (Ns/Np) = 46/50
Current sense resistor = 0.15 Ohms
Continuous conduction Mode.
Duty cycle at max load (20R) = 0.24
...its for Class B amp supply. (output is actually +/-40V, but lets call it 80V...i hope thats OK?
Old 26th September 2012, 06:37 AM   #2
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
It's over my head but TI has a free downloadable spice simulator for it's own products that will do this for you, called Tina.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 26th September 2012, 08:22 AM   #3
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Current loop: pole at Rsense and (Lout/turns ratio) i.e. R/2piL
Voltage loop: pole at Cout Rload i.e. 1/2piRC, zero at Cout ESR i.e. 1/(2*pi*ESR*C)
no tricks here.
Old 26th September 2012, 02:40 PM   #4
Terry Given is offline Terry Given  New Zealand
yes. and given that Treez cant play with the current loop at all, might as well pretend its perfect, and treat the entire power stage as a transconductance. gm = delta_Iout/delta_Vcomp. thats pretty easy to work out - but dont forget the x1/3 from Vcomp to Vcurrentsense
Poles and zeros for two transistor forward?Hide this!Advertise here!
Poles and throws? MagnumOpus Analog Line Level 17 17th April 2012 10:36 AM
Poles or feedback 101 tvrgeek The Lounge 9 16th January 2012 01:51 PM
correct # of poles source selector? h_a Solid State 2 6th February 2007 09:28 AM
Best source of ones and zeros? tmd1 Digital Source 16 29th September 2003 10:12 PM
Ones and zeros recorded on CDs chris ma Digital Source 60 25th March 2003 09:46 AM
Copyright ©1999-2017 diyAudio
