how to wind coupled inductor on toroid - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd September 2012, 02:34 AM   #1
gearheadgene's Avatar
Default how to wind coupled inductor on toroid
I want to wind a toroid as a coupled inductor (it's for a forward smps). There are 4 windings : +/- 40 and +/- 7
It's no so important that the +/-7 cross-regulate, but definitely want the 40 volt windings tight. At the moment, I am experimenting with windings. One thought is to take 4 strands of #24 wire and twist them up with drill. Then wind the toroid, about 50 wraps. Then take the 4 strands, use 2 for +40 and the other 2 for -40. Seems that will couple pretty tightly. But the toroid, T130, isn't quite big enough to do this in one layer - I wound up with about 40 wraps in a single layer. It's okay to go the extra distance and continue wrapping, I think. but . . .
If I wrap a single strand of #24 wire, it fits all 50 wraps with a lot of room. What if I then lay a second wrap along side the first wrap, then the 3rd along side the 2nd and the 4th along side the 3rd. Assuming this fits, does this seem a reasonable method to ensure a single layer and, more importantly, tightly coupled?
The 7V windings will be about 8 wraps each, and will sit on top of the 40V windings.
Does this seem reasonable or are there better ways?
Old 23rd September 2012, 09:59 AM   #2
AndrewT is online now AndrewT  Scotland
I would wind the two 40V as a bi-fillar, not twisted.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd September 2012, 12:05 PM   #3
You mean the 2 wires in parallel, I think, wound at the same time. Is that really different than twisting the 2 together and winding it at once?
Old 23rd September 2012, 12:17 PM   #4
AFAIK, it's always a matter of increased magnetic coupling at the expense of capacitive coupling. If you twist the wires you'll increase the copper losses because it will take more wire to make a turn. You'll also increase the capacitance between the wires, though I don't know if that's actually a problem. Bifilar winding (parallel, side by side) is what's normally done. Multiple layers should be no problem.
I may be barking up the wrong tree, but at least I'm barking!
Old 23rd September 2012, 05:14 PM   #5
thanks for the help - I tried it bifilar, just as suggested -it looks good. For now, the wire guage is probably too small - so eventually will try it with larger wire.
If the amount of required turns is 50, and I can fit 40 on one layer - which is correct, wind the remaining 10 wraps on the second layer or wind 25 on each? Seems to me that it should be 25 each.
How to make a coupled inductor using Toroidal core? pandusambu Power Supplies 11 22nd January 2012 10:11 AM
Current mode and coupled output inductor? eem2am Power Supplies 13 21st September 2011 08:18 PM
how to wind toroid transformer? openport Power Supplies 9 16th February 2011 05:26 PM
Coupled output inductor in BTL? Khron Class D 28 30th June 2010 02:27 AM
coupled output inductor in dual smps schiller Power Supplies 4 7th April 2010 08:10 PM
Copyright 1999-2017 diyAudio
