Advice on a +150VDC/-100VDC power supply
Old 22nd September 2012, 05:53 PM   #1
DrExotica is offline DrExotica  United States
DrExotica's Avatar
Default Advice on a +150VDC/-100VDC power supply
I am looking to build a power supply for a tube circuit and need to supply two voltages, +150VDC, and -100VDC. I have built a fair number of power supplies for tube circuits, but never one that provides negative voltage. I would be most appreciative if someone could explain, or provide an example, of a power supply for tube circuits that provides negative voltages (I have the suspicion it is a pretty simple trick). As for the current requirements, they will be large (driving >50 tubes); I will deal with this as a second phase of the design activity ...
Many thanks
Erik
Old 23rd September 2012, 07:52 AM   #2
Elvee is online now Elvee  Belgium
Elvee's Avatar
First thing to do is to decide which is your "main" supply (power? ...), implement it in a normal way, and then see if it is possible to derive your other voltage simply and efficiently.
Do you already have a base? Can you post the schematic (and the requirements)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 23rd September 2012, 10:05 AM   #3
R.I.P.
same current fro both polarities?
regards Andrew T.
Old 23rd September 2012, 05:46 PM   #4
DrExotica's Avatar
Mains voltage are 120VAC; the current requirements will be much larger for +150VDC; -100VDC is for bias.
Sounds a bit odd I'm sure - I am building a digital circuit using tubes as a crazy project.
Erik
Old 23rd September 2012, 07:17 PM   #5
Elvee's Avatar
Then the 150V can be processed normally, and the -100V can easily be derived by a wart charge pump grafted onto the main rectifier.
The voltage will be too too high, but that is not a problem if the power is reasonable.
Old 23rd September 2012, 11:49 PM   #6
DrExotica's Avatar
Hi Elvee.
Thanks so much for the info. I must appologize but I am not familiar with a 'wart charge pump'. Any additional info/clarrification would be most appreciated. Many thanks.
for fun, search for 'IBM 604' for some cool schematics if you're an EE guy ...
Erik
Old 24th September 2012, 03:17 AM   #7
multisync is offline multisync  Canada
if your transformer is center tapped use a full wave bridge. You will get +/- whatever and then you can regulate down.
Old 24th September 2012, 12:23 PM   #8
Elvee's Avatar
This example will provide +150V@1A and -100V@10mA from 120VAC.
Values can be adapted to suit your exact requirements.
Advice on a +150VDC/-100VDC power supplyHide this!Advertise here!
Inexpensive Adjustable DC Power Supply (Up to 100VDC) DreadPirate Solid State 1 5th March 2012 02:13 AM
need power supply advice for future power amp project. boricuaso Chip Amps 13 6th February 2008 02:24 PM
Some advice on this power supply Richard Tubes / Valves 11 23rd June 2006 05:21 AM
