Behringer Europower PMH1000 blown psu fixed
Old 22nd September 2012, 12:30 AM   #1
slideman82 is offline slideman82  Argentina
Default Behringer Europower PMH1000 blown psu fixed
I have just repaired its power supply for second time, and I'm still listenning some kind of rattle around switching power mosfets (replaced blown 17n80 with IRFP450's and reversed cooler fan for better cooling). Is this normal?
Old 1st October 2012, 07:45 PM   #2
Is this normal?
Old 2nd October 2012, 11:42 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
If it keeps blowing up then something is wrong or you are driving it too hard.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 3rd October 2012, 12:18 AM   #4
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
There is a problem with the amp module on some of these that use the switching amp section. it seems when Behringer stole the design from Yamaha they neglected to duplicate the board layout. The output transistor will arc over and char a path from one leg to the next. sometimes through the middle of the board. IF...this is the case. then when the transistor arcs over, it kills the power supply. often times it kills the amplifier too! can't remember what model that is however.
It's not about what you can BUY...It's about what you can BUILD!
Old 3rd October 2012, 02:12 AM   #5
Huh, what a problem! But... this kinda rattle I hear could be an arc over transistors? First time I repaired it (I didn't change the TOP221 ic, and some hours of use later switching power transistors blew up, and some other things I changed then) there where no rattle...
It's a big help, btw! Thanks!
Old 13th October 2012, 12:58 PM   #6
musiccankill is offline musiccankill
Hello..!
I have got a pmh1000 with a blown power supply 2..
At first i could only see (also checked with component tester everything on the board) a tottaly fried DIODE (D24 smd) i replaced it with a 1n4007 and powered it up without anything connected (mixer or amp)..
It started working and i could hear a buzzing sound from the power supply...
I left it on for 3-4 seconds...
Then i connected the mixer and it worked grat for another 3-4 seconds..
Then i also connected the power amp..
Left it on for 3-4 seconds and i could hear a buzzing sound from the speakers too...(as loud as the music)...
The after i checked for pieces that may have warmed up (there were nothing heated) i turned it on and left it playing...
I knew the buzzing was not ok but i left it on..
~30 seconds later, it blew up (no popping sound on speaker)
Just a sparkle from the power board and the fuse blown..
I checked the power board and the 4 resistors after the power bridge along with the 17n80c3 mosfets are blown up (haven't seen anything else blown till now)...
Thanks god the power amp is still not fried (checked it again with component tester and everything seems ok...)
Any help here?
Old 26th October 2012, 02:41 PM   #7
Fergytron is offline Fergytron  United States
Check the electrolytics for any leakage or pooching.
Old 29th October 2012, 05:01 PM   #8
Originally Posted by musiccankill View Post
Hello..!
Any help here?
Check the output transistors, could be that. I hate these PMH1000... it failed all around the world!
Old 6th November 2016, 06:56 PM   #9
I just got in searching again for this for a friends one so i wanted to update on that situation..( i know i am reviving an old thread but it is to add info that may help others!! )
It wasn't the power amp as i am using the power amp since then with an external psu without problems..I never found what it actually was because after the dead diode (the one i have replaced) it burned along with the diode all the power transistors in the psu too and they are not cheap (would cost almost as much as a used one) so i never actually fixed it..I just made a custom psu to power it without the amp and use it as a simple mixer and PSU board has been used for parts..
Behringer Europower PMH1000 blown psu fixedHide this!Advertise here!
Need service manual or schematics of behringer PMH1000 mixer fredos Instruments and Amps 20 11th July 2017 06:57 AM
Behringer europower pmh1000 blown psu laserlight Power Supplies 10 25th October 2012 06:53 PM
Behringer EUROPOWER PMP518M-need schematic ID_ PA Systems 4 2nd December 2011 12:39 AM
Behringer Europower EP1500 sterjess Instruments and Amps 1 27th March 2010 08:41 AM
Behringer EuroPower 1500 review longblock454 Instruments and Amps 7 24th April 2008 08:37 AM
