Help with SMPS - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Closed Thread
Old 21st September 2012, 02:28 PM   #1
Default Help with SMPS
I am trying to build this half bridge SMPS, modified/improved PC design, operating from 230V AC providing about 13.8V DC with MOSFET rectifiers. Operates at 50kHz.
250 W S.M.P.S. with Power-FETs James Arthur
1. There is a snubber of 2.2nF / 100 Ohms across the primary winding. The resistor wattage is given as 2W. I tried calculating the wattage, as
50000 X 4 X (CV^2) / 2, as there are 4 transitions per cycle, with V taken as 190V, half of peak voltage, at input high 230*1.15*1.414. With that I am getting a Pd of around 6W.
2. There is a snubber of 10nF / 10 Ohms across the secondary. Here also the resistor is specified as 2W, but my calculation like the above, with a secondary peak voltage of 33.25 X 2, gives a Pd of 4.4W! Am I making a missing something or my snubber calculation is wrong?
3. Can I use a still lower RdsOn MOSFET like 2.2 mOhm NXP PSMN2R0-60PS,127 instead of the IRFZ44 used in the original schematic, for output rectification to improve efficiency further? Will those parameters like, higher gate charge, capacitance matter?
Thanks in advance.
Old 21st September 2012, 08:20 PM   #2
Mooly's Avatar
Non isolated supplies of this kind are potentially lethal and are against the forum rules.
Thread closed.
Closed Thread
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 05:51 PM
Smps a2005r2003 Power Supplies 19 11th August 2011 06:19 AM
Is this really an SMPS? TylerDurden Power Supplies 9 14th July 2011 11:03 AM
Smps rinox Power Supplies 0 2nd September 2005 10:05 PM
Smps hugefathead Solid State 8 5th March 2004 03:44 AM
Copyright 1999-2017 diyAudio
