How to split single 40v into +/-15v ? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th September 2012, 09:15 PM   #1
payloadde's Avatar
Default How to split single 40v into +/-15v ?
I need to get +/-15v 300mA max varying / non-symmetric load currents on both +/-.
No need for high precision though.
There is only a single 40v 1amp available inside the box.
I first thought about just using a pair of 7815/7915 but don't think it would work now ... or does it ?
The only other idea I have so far is to first regulate to 30v and then split via zeners.
Will #1 and/or #2 work ?
Are there alternatives ?
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 19th September 2012, 01:12 AM   #2
DUG is offline DUG  Canada
They will both work.
But beware of the temperature effects on Zener regulation points.
If you are concerned about the regulation headroom on LM7x15 regulator take a look at this cct using 21-22V zeners.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 19th September 2012, 07:13 PM   #3
payloadde's Avatar
My concern with #1 is as follows:
what if I load the +15v rail but not the -15v (or much less)
there's no return path from the virtual ground to the actual power supply ... !?
Old 20th September 2012, 02:28 AM   #4
Through the npn (or pnp) transistors.
They (with the zeners) will put the ground point within a volt or two of half.
This will make sure each regulator has headroom independent of load imbalance.
I've used this type of circuit of dozens (yes, dozens) of times with a 30V isolated supply to get -4V and +26V supplies. It was only running a couple of instrumentation amplifiers so I did not need the transistors but the idea is the same.
In your case if there is a load imbalance there will be a shift in regulator supply potential. This is what the "line regulation" part of the regulator spec is for.
Old 20th September 2012, 07:57 AM   #5
you cannot do this if u have sigle power supply....put two diodes one side cathode and anothr one anode on one terminal and use other terminal as gnd....and then regulate it....
Old 20th September 2012, 08:13 AM   #6
bjaris is offline bjaris  Sweden
I have been using this schematic with good result.
http://hem.bredband.net/hififorum/schema/Power.png
Old 20th September 2012, 11:36 AM   #7
zigzagflux's Avatar
Works like a champ
Old 20th September 2012, 01:18 PM   #8
Elvee is offline Elvee  Belgium
Elvee's Avatar
#2 will work, but will be touchy about the adjustment: you could easily fry the zeners, or end up with a "dead-band" of high impedance in your ground.
You could increase the 1 ohm resistors, but of course this will reduce the available current
The circuit will fry the zeners if the 1A supply is not limited in some way
This circuit is not properly compensated and will exhibit a huge impedance peak somewhere in the KHz range.
Depending on the amplifier and the 470µ's parameters, it could even oscillate under certain conditions.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 20th September 2012, 06:16 PM   #9
paulb is offline paulb  Canada
Originally Posted by zigzagflux View Post
Works like a champ
2x TL431 for small loads, ok, but with 300 mA loads?
Old 21st September 2012, 12:13 AM   #10
A 21V zener (example DDZ21) has a tolerance of 20.64V to 21.71V at 5 mA of test current and is rated for 500mW.
At 20V the current will be less than the 5 mA of test current and therefore less than the 105mW that would be dissipated under test conditions.
I don't believe they will fry at 20% of rating.
Using a 50v single supply (and trying to split it) with LM3886 mudihan Chip Amps 47 9th March 2009 07:12 AM
Avel Lindberg 40v+40v toroidals sell or trade mtj Swap Meet 2 16th July 2006 04:06 PM
How to split a single supply cm961 Parts 13 9th October 2004 03:17 PM
Trafo- 225VA , single 117V primary, Dual 40V secondaries Illusus Swap Meet 3 11th December 2003 04:07 AM
Copyright ©1999-2017 diyAudio
