Toroidal Transformer additional windings
Old 14th September 2012, 03:58 PM   #1
audiorookie is offline audiorookie
Default Toroidal Transformer additional windings
Hi all.
I have a toroidal transformer with two secondary windings, each giving a 38V output. I will connect these in series to give me +38V, 0V and -38V. I am just wondering if anyone knows if it is possible to add extra windings over the top of the insulating layer of the toroid, from the 0V point, to give, say, +/- 15V? I would use this for an op amp in the preamp stage. Is this a possible way? Or am I completely heading in the wrong direction?
Thanks.
Old 14th September 2012, 04:17 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Toroidal Transformer additional windings Send a message via AIM to Peter Daniel
Yes, it is possible., I did that in this design: AudioSector-chip amp kits, dacs, chassis and it worked perfectly fine.
To order kits contact me through forum mail.
Old 14th September 2012, 06:41 PM   #3
Thanks for your reply, I will give it a go then!
Old 15th September 2012, 08:24 AM   #4
R.I.P.
0.6mm diameter enameled copper is perfect for low current windings.
The 0.28sqmm can give upto 0.9Aac of continuous output.
That would be ~400mAdc of continuous current after the bridge rectifier and ~1mF of smoothing.
0.6mm is easy to straighten and to wind. A 500gm reel has a lot of metres on it for many projects. It even makes very good air cored inductors to experiment with CLC supplies.
regards Andrew T.
Old 15th September 2012, 11:50 AM   #5
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
if the middle of your torroid is potted, you will have to remove it first...wind a test coil of say ten turns to determine the turns per volt...since volts/10 helps you with the number of turns required,.....
if you want +/-15volts i assume that that is regulated so you will need at least 15-0-15volt ac winding....wire will be small so that you can do bifillar winding.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Toroidal Transformer additional windingsHide this!Advertise here!
SMPS transformer windings shorting sphinx Power Supplies 2 1st January 2010 01:36 PM
Using existing transformer winding to provide and additional supply BL21DE3 Tubes / Valves 3 23rd October 2007 11:56 AM
Transformer Windings impsick Chip Amps 6 2nd February 2007 11:00 AM
transformer primary windings Q AndrewT Power Supplies 6 28th October 2006 11:51 AM
Transformer windings identifications - how to get it? Alfetta87 Solid State 7 21st February 2005 04:01 PM
