I'm planning to build a SET and favour the use of a fairly beefy power transformer. I'll be wanting around 500V for B+.
I would also like to play around with some Class A solid state amplifiers. I'd need about the same power rating for the transformer. Using separate transformers isn't needed as I'll only use one amplifier at a time. And it would save both cost and considerable weight to use only one transformer. So I thought that if I simply reverse the transformer, instead of 500V output, I will put 120V into the B+ winding and extract a useful 30V or so from the other winding. I can't see an issue with this, either from a power point of view or safety. But I'd be interested to know if anybody else has some advice on this ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#2 |
I doubt whether the current rating of the Primary winding would be sufficient for a Class A amplifier.
#3 |
It will work, but if you use a transformer at a lower voltage, the series impedance (winding resistance + leakage inductance) will remain the same, and this means the regulation will be very much degraded compared to a regular transformer.
In fact, if you draw the normal current acceptable to the primary (now your secondary), the voltage could be halved or thereabout.
#4 |
if it works. the VA rating will be about 25% of the normal value.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#5 |
Very helpful response to my question - I'm very glad I asked it ! Thanks.
| Power Transformer for Class A Amplifiers -- What are your experiences ? | EUVL | Pass Labs | 20 | 3rd March 2011 08:06 PM |
| transformer coupled amplifiers | latala | Solid State | 11 | 27th February 2006 03:26 PM |
| transformer coupling, magnetic amplifiers, grid leak current | metebalci | Tubes / Valves | 9 | 24th March 2004 11:22 AM |
| pro amplifiers vs. home audio amplifiers | bonsai171 | Solid State | 26 | 25th February 2004 08:24 PM |
| Paradigm amplifiers? Anthem amplifiers? | Corn-Picker | Solid State | 2 | 24th January 2004 03:10 AM |
