i have the evaluation kit from DAISY. It has a SMPS which they suggest should be replaced with a linear supply. It needs to supply 5 and 9 volts. Does it need to be regulated? Can you suggest a good design or preferably, a kit or pre built supply that would be suitable. How complex does it need to be and of what quality? Thanks
here is a linear PSU kit made for CDpro2
Dantimax (elektronik) - Digital_audio
The smps that is supplied is the one DAISY designed as a production unit to go with their SACD/CD transport, supposedly a high end unit. Yet they still suggest linear supplies for the CDPro. What comes off the CD is an 80khz rf signal and the smps's mostly use around a 40khz switching frequency so I guess there could be some interaction from the servo and laser voltages. Who knows? Regards and thanks. I may go with the Danish ps. I may need your help in wiring it up though.
I have the complete kit coming from DAISY, CDMPro, smps, display and controller, remote, and all cables. I will listen to this first, then decide if I need the linear supplies. I am glad to know that there is expertise here in making all the fiddly bits work properly. Thanks again for all the input. Kindest regards
- Power Supplies
- Power supply for Phillips CDPro2
