Transformer Winding Convention - Dual Primary?
Old 6th September 2012, 09:40 PM   #1
Adipocere is offline Adipocere  United States
Default Transformer Winding Convention - Dual Primary?
What is the typical way to wind dual primaries for 120v/240v operation?
First part in several layers and then second part?
Alternating layers of first and second parts?
Bifilar?
Something else?
Old 7th September 2012, 09:27 AM   #2
R.I.P.
I think they are bi-fillar. Hopefully Tony, or some other Member sees this.
That puts the full 120Vac across the two layers of insulating enamel.
You really must be sure that the enamel is not damaged by your handling and winding procedures.
For a home wound primary I would be tempted to go for two separate windings with each layer insulated from the lower layer to give some confidence in holidays not shorting out your primary.
But, I would never attempt to wind a mains primary, simply because I can't accept the risks involved. Would my insurance company pay out if my house burnt down?
regards Andrew T.
Old 7th September 2012, 09:28 AM   #3
DF96 is offline DF96  England
Definitely not bifilar or alternating, as you need to maintain good insulation between the two primaries. Either first part, then insulation, then second part, or side-by-side with insulation between.
Just my guess as I am not a transformer expert! I would personally never attempt to wind a mains primary as I know I don't know enough to do it safely and reliably.
Old 7th September 2012, 11:00 AM   #4
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i would not recommend bifillar, although i have done an isolation type 230volt ac transformer using #16 magnet wire on a 1.75 inch core stacked to 3inches and still in service to this day after more than 5 years, i am still using it......this is one of those, don't do this at home thingy....
one after the other and with proper insulation is the way to go.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th September 2012, 08:23 PM   #5
Thanks guys.
Transformer Winding Convention - Dual Primary?Hide this!Advertise here!
Dual Winding Toroidal Transformer for Sale AAK Swap Meet 19 25th August 2012 07:47 AM
Dual primary transformer help JZatopa Parts 9 1st August 2012 04:02 PM
transformer primary winding turns AndrewT Power Supplies 19 20th December 2010 01:11 AM
Using primary as the secondary winding in the power transformer. mishak Parts 10 30th May 2010 05:55 AM
Transformer primary winding question gary h Power Supplies 4 21st December 2008 06:21 PM
