Ceramic resistor question.
Old 30th August 2012, 04:23 AM   #1
Rod Beauvex is offline Rod Beauvex
Default Ceramic resistor question.
Are ceramic resistors supposed to get extremely hot? I mean to the point of burning you the immediate instant your skin brushes it? I've had two different tube units, both of which had at least one ceramic for voltage dropping, and they both run piping hot. Is this normal, or indicative of other problems?
Old 30th August 2012, 08:22 AM   #2
sofaspud is offline sofaspud  United States
sofaspud's Avatar
They can run very hot, yes. Measure the voltage across it and calculate the current; compare that with the nominal designed voltage & current.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 30th August 2012, 08:37 AM   #3
Mooly's Avatar
Yes it can be normal. Normal to the point that you need high melting point solder to stop them unsoldering themselves.
Old 30th August 2012, 12:53 PM   #4
Ceramic resistors?
Do you mean wire wound inside a protective case?
regards Andrew T.
Old 30th August 2012, 02:34 PM   #5
Possibly andrew, yes. Point is, they get hot.
Ultimately, I threw away a tube receiver, albiet a low end one, due to my ignorance on what is normal for how hot these get.
Old 31st August 2012, 06:17 AM   #6
eem2am is offline eem2am
Banned
Rod, do you mean those white "bathtub" resistors..... the ones that look like a bit of a tile off the side of the space shuttle?..theyre usually rectangle shape.
...if so , yes, in a television company i once worked for....we used to have one in series with a flaback smps...the reason....just in case there was a short across the primary and otherwise the current sense resistors might blow off the board....(health and safety)
Old 31st August 2012, 11:36 AM   #7
DF96 is offline DF96  England
Those white ceramic resistors are not very good under severe overload conditions, as they tend to explode. Fine for regular hot use, but if a severe overload is possible then 'health and safety' suggests vitreous enamel encapsulation (often dark green in colour). A TV company ought to know this.
Ceramic resistor question.Hide this!Advertise here!
resistor question mike49504 Car Audio 1 12th August 2007 12:18 AM
Using a resistor Question DARTICUS Everything Else 2 29th April 2007 09:40 PM
Ceramic Resistor Max Temps? Zero Cool Solid State 10 10th July 2005 01:37 AM
ceramic cap from rca grounds to circuit question crippledchicken Parts 4 3rd August 2004 04:51 AM
Resistor Question jcs302 Multi-Way 4 24th March 2002 02:52 AM
Copyright ©1999-2017 diyAudio
