Audio Junkie
I would like to build a variable constant current source for experimenting with various stage topologies. I would like something that is variable from say 1ma to more than 10ma maybe as high as 100ma?
any suggestions?
It's not about what you can BUY...It's about what you can BUILD! |
#2 |
xen-audio.com |
#3 |
Audio Junkie
I will take a read. I think I may have some of those? I will have to look
#4 |
This might be of interest to ya, mate!
Constant Current Source/Load (LM317) | The Paranoid Troll In general, the LM317 IC is used like this: I did a quick Google search, based on my memory of seeing this in a data sheet once upon a time. I am sure that there are other resources about this out there. -Charlie |
#5 |
A more modern alternative to LM317 for low current:
LT3092 - 200mA 2-Terminal Programmable Current Source - Linear Technology I also use LM317 or LT1083, etc., but usually for current above 500mA. Patrick
xen-audio.com |
#6 |
while regulators can be hacked to give CCS they often have limited bandwidth
purpose designed chip: LT3092 - 200mA 2-Terminal Programmable Current Source - Linear Technology can also make "Howland Current Pump" with op amps or power chip amps depending on requirements http://www.ti.com/lit/an/snoa474/snoa474.pdf |
#7 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
A solution that will encompass 1mA would be an opamp driving the gate of a MOSFET with a resistor to a power rail from its source. -ve input of opamp to source, +ve input of opamp you feed a voltage which defines the current you want. Choose the resistor to suit the current range you require. You need an opamp whose CM input voltage goes down to the -ve supply with an N-channel MOSFET - this makes a current sink. For sourcing, a P-chan MOSFET is called for and the opamp needs to allow CM voltages up to the +ve supply.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#8 |
A depletion mode mosfet, like the DN2530 or DN2540, will make very good current sources up to about 100mA. See attached drawing.
pb |
#9 |
Audio Junkie
I have plenty of DN2530's on hand. I like that solution. a little limited at only 25ma but that will work for most things. I will review the others, thank you everyone!
#10 |
Why not something simple like this. Almost any general purpose npn and power mosfet will do. Play with R1 and R2 to get the current you want.
| N-channel JFET + multiturn trimming potentiometer = variable constant current diode? | Groundloops | Parts | 4 | 26th February 2012 05:50 PM |
| constant current source | tubem | Pass Labs | 26 | 4th September 2011 10:48 AM |
| Why is it not a Constant Current Source ? | payloadde | Power Supplies | 3 | 17th April 2011 09:59 PM |
| constant current source | hacknet | Solid State | 19 | 13th March 2006 02:46 PM |
| 3 constant current source questions | Jef Patat | Solid State | 12 | 18th January 2005 02:30 PM |
