Hello guys, I am new around here and I need some help to build my SMPS transformer.
I was thinking designing a transformer to use on a forward converter. My goal is to, first, learn how to do a transformer and second, how the forward converter works. I was wondering if there is someone who can help me out here with the design of that trafo. I will wait for some answers and see if someone can help me. After that, I'll post the specifications and the calculations that I have done so far. Kind Regards. |
#2 |
Hi again.
Maybe would be better to post directly the specifications. Specifications Input Vin = 230VAC Vin(nominal) = sqrt(2) * 230VAC = 325V Vin(minimum) = 300V Vin(maximum) = 350V Output Vout = 30V ; Iout = 5A ; Pout = 150W Expected efficiency = 80% Pin = 150W / 0,8 = 190W Iin(maximum) = 190W / 300V = 0,65A Transformer specifications: I got this transformer from an old power supply. It is an EI type core. I don't know what kind of core material and because of that I do not intend to strive the transformer that much. The specifications are: Bmax = 1600Gauss Ae (center leg cross-section) = 1,21cm2 f = 100kHz TRANFORMER CALCULATIONS Just before start, I have a couple of questions here. From what I have read, in forums, books, applications notes, there are two methods to calculate the primary transformers turns. The first one is: Np = ( Vin(min) * Delta(max) ) / (Ae * Bmax * f ) Ns = Np * ( (Vout + Vf * Delta(max) ) / ( Vin(min) * Delta(max) ) ) The second one is: Np = ( Vin(max) * 10^8 ) / ( k * f * Ae * Bmax ) Ns = Np * ( ( Vout + Vf ) / Vin(min) ) The Ns, from the first method I saw it on a paper, but I have seen too the Ns from the second method, applied on the first. I have calculated the turns with both methods and both turns gave me completely different values. Here they are: Using the first method I got: Np = 70T ; Ns = 17T; Using the second method I got: Np = 45T ; Ns = 5T; Now my question is, which method should be used? Why they give so different values? The method that doesn't use the Delta, is less accurate than the other? I would appreciate if someone could help me out. Kind regards. |
#3 | |
It will go a long ways in explaining things. After you have read through it we can chat some about the important design considerations around a forward converter. Tony |
#4 |
Thank you Tony. I'll read that.
Regards. |
#5 |
Here is a fairly thorough treatment of a forward converter that I wrote about 10 years ago but it still applies today.
Tony |
| Winding SMPS transformer | Sara001 | Power Supplies | 8 | 4th June 2012 10:35 AM |
| Using a large 60hz toroid transformer as an SMPS transformer | EWorkshop1708 | Power Supplies | 20 | 22nd June 2011 08:05 PM |
| SMPS transformer | jegandren | Parts | 4 | 24th April 2008 01:30 AM |
| transformer for SMPS | jarthel | Power Supplies | 2 | 22nd June 2007 02:17 PM |
| SMPS Transformer Equations | jackinnj | Solid State | 7 | 21st March 2003 12:28 PM |
