Flyback SMPS for high power....eg...350W - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th August 2012, 08:57 AM   #1
Banned
Default Flyback SMPS for high power....eg...350W
We are going to do another class D amplifier power supply, and we are going to use a Two switch flyback.....350W, and Vin = 90-265VAC.
DoeS any reader have objections.?
If you do object, then do you understand that Continuos conduction Mode boost converter power factor correction stages are regularly done at 400W plus?
And do you appreciate that a two switch flyback is no more noisy than a continuous mode boost converter power factor corrector?
I think i have prooved that Flyback is ok for 350W...
The only argument against it would be if you want a really miniature power supply size.
Old 26th August 2012, 09:22 AM   #2
Frex is offline Frex  France
Generally, (but not always !) flyback converter is restricted to 0-200W range.
The main issue with flyback converter is the high voltage on the primary switch at turn-off that must be mastered in the Vds max of the MOSFET, that is not always easy because it depend on the leakage inductance of the transformer.
In boost converter (like PFC), you don't have this issue.
Frex
Old 26th August 2012, 03:09 PM   #3
Banned
Thanks Frex, -but here i am discussing two switch flyback, and the drain voltage is clamped to Vin.....its not a problem.
350w SMPS troubleshooting. mb3 Power Supplies 6 1st February 2012 08:15 PM
Single switch flyback for 350W eem2am Power Supplies 12 14th December 2011 11:54 AM
Project for the SMPS 350W! radio Power Supplies 1 24th August 2011 09:14 AM
Wtb: 36v 350w smps[eu] igor0203 Swap Meet 2 5th June 2010 07:48 AM
SMPS Power supply 350W 100v CT Regulated Bent Swap Meet 0 25th August 2005 07:57 AM
Copyright 1999-2017 diyAudio
