48v Phantom voltage from 30v smps
Old 23rd August 2012, 02:49 PM   #1
graygem is offline graygem  United States
Default 48v Phantom voltage from 30v smps
I would like to create the 48v phantom power from my 30v 300w smps. Did a little google searching and I was thinking about trying the MC34063. Can it be done or is there any other suggestions. I am powering 2 mics.
Professional Newbie.
Old 23rd August 2012, 02:55 PM   #2
simon7000 is offline simon7000  United States
Very few microphones require true 48 volt phantom power. So if for fun you want to make one you actually need 52 volts. Otherwise most any voltage above 12 volts will work. Most microphones convert the voltage to a constant current so all the lower voltage does is create less heat.
Old 10th September 2012, 08:45 PM   #3
Thank you for your reply.
Old 9th October 2012, 12:34 PM   #4
Just had a thought, why do I need 52 volts to get a 30 - 48 volt boost? Thank you.
48v Phantom voltage from 30v smpsHide this!Advertise here!
48V phantom supply for mic 454Casull Instruments and Amps 9 7th August 2012 12:44 AM
xlr and 48v phantom power to pc oublie PC Based 7 14th November 2009 03:40 PM
+/-15V from +48V Phantom Pilbromatic Parts 4 9th August 2009 05:46 AM
sounds silly .. but do i need a 48v phantom power ? Ahmad_tbp Solid State 8 3rd February 2007 10:36 AM
48v phantom / resistor is way hot ! redrabbit Solid State 12 15th February 2006 08:14 AM
