downside of using computer bus capacitors?
Old 18th August 2012, 04:51 PM   #1
CharlieLaub is offline CharlieLaub  United States
Default downside of using computer bus capacitors?
Computer grade buss (screw connector) capacitors seems to be readily available, both new, new-old-stock, and used. These seem to be well matched to what you need for an amp power supply in terms of capacitance (5,000 - 50,000 uF or more) and voltage rating (e.g. 50VDC - 100VDC or more).
The screw connectors seems to be practical for connecting wiring or bus bars.
What's the downside if any? What is the relative ripple current and ESR for this type of cap versus the usual large snap-in variety?
-Charlie
Old 18th August 2012, 04:59 PM   #2
For instance, currently available at Mouser:
22,000uF 63V screw terminal United Chemi-Con capacitor $16.50ea QTY1
Similar to this:
-Charlie
Old 18th August 2012, 06:27 PM   #3
R.I.P.
Generally the esr and ripple rating are slightly better than "normal" commercial/industrial grade capacitors.
Generally they are more expensive than those as well, but usually not as expensive as the "exotics" that are offered to the audio builder.
Sometimes they are bigger.
regards Andrew T.
downside of using computer bus capacitors?Hide this!Advertise here!
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
FS: BC 30v 55000uf Computer Grade Bus Capacitor phuongmitec Swap Meet 3 12th December 2010 11:21 AM
Computer Grade Capacitors Witchdoctor Tubes / Valves 14 6th January 2006 03:12 AM
Is There Any Downside to Lowering Gain? Cappy Chip Amps 5 2nd September 2004 07:08 AM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
