Help needed for tube power supply design with unknown choke..
Old 25th August 2012, 06:44 PM   #11
Austin Translation is offline Austin Translation  United States
Austin Translation's Avatar
Send a message via MSN to Austin Translation Help needed for tube power supply design with unknown choke..
Originally Posted by Austin Translation View Post
Suppose I connect both the amps power supply transformer secondaries in series for 1400 volts and then to drop the voltage back down to 700 volts I run the power transformer primaries in series with each other. Seems like a great idea but if it were, surely everybody would be trying to do it. I could get four voltage referances.
Sorry I was very tired when I posted this, it is a silly idea. They wouldn't stay in balance and one would get more curret than the other depending on the load.
Help needed for tube power supply design with unknown choke..Hide this!Advertise here!
help needed with tube voltage power supply freefuzz Power Supplies 2 9th November 2010 01:49 PM
230VAC to 5VDC 2A SMPS power supply design needed. Wynand Power Supplies 4 21st June 2010 05:27 PM
Power supply choke help needed audiobliss Tubes / Valves 4 1st August 2008 04:22 PM
choke power supply design info? dorkus Tubes / Valves 3 21st November 2007 12:24 AM
tube power supply design resources Curly Woods Tubes / Valves 3 21st January 2007 04:21 AM
