SMPS with output supply of +-70V for audio amplifier
Old 18th August 2012, 02:04 AM   #11
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Thumbs up HELLO
Hi Kikodemy
greetings well at this very moment i and irvynejay are putting
components on the pcb work is going on hope it works well its my starting point in SMPS power supply all results will be posted here for all to make everyone is making 3kw per channel d class amps SMPS POWER SUPPLY is the
need for the moment
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 18th August 2012, 02:50 AM   #12
john carlo is offline john carlo  Philippines
sir have tried this SMPS
Old 18th August 2012, 03:11 AM   #13
kikodemy is offline kikodemy  Philippines
Default SMPS of Powerbob
Thanks Mr. Powerbob although your schematic of
SMPS -+70 is not 70v but only -+50v..but
this can help a lot me becoz I can relate to it
easily..thanks again and keep up the good work!
Old 18th August 2012, 03:33 AM   #14
this can help me a lot becoz I can relate to it
Old 18th August 2012, 03:44 AM   #15
Default reply to Mr. Andrewlebon
Hi too Mr. Andrewlebon!..your project that you
are working right now is really amazing coz of its
power capabilty..I know it is very costly if not
mistaken..especially here in our country..anyway
best luck to both of you sir and hoping for your
success..thanks!
Old 21st August 2012, 12:53 AM   #16
Default smps supply 1200 watts
Hello
greetings this smps prototype made by sir irvynejay testing under progress many thanks to SIR DETEX AUDIO for his valuable suggestions
warm regards NANO YOU ALSO HELPED US
andrew
Old 21st August 2012, 01:35 PM   #17
sir!....andrew lebon i will try ur smps can u plz send me the complete diagram of this tnx.my email ad johncarlo_seno0312@yahoo.com.
Old 22nd August 2012, 10:47 AM   #18
Sir andrew lebon the prototype made by sir irvynejay looked
so nice..it seemed to be simple but powerful smps project..
here is my email kiko_antonio71@yahoo.com if you would
share me the same project..warm regards!
Old 26th February 2013, 08:45 AM   #19
adamkaktus is offline adamkaktus  Poland
adamkaktus's Avatar
i know that it is old topic, but did you assembled this SMPS? does it work properly? Can i have copy of files to make it for my own?
adamkaktus@wp.pl
Old 7th March 2013, 06:16 AM   #20
ok sir adamkaktus..i already made my own version of that smps...but it's been undergoing the series of testing yet, to make it really ok..it is half bridge, offline with 220v input, using
k2611 mosfet..is this fet available in your place?....the output is 50v and i still have to modify the winding to make it dual +50v, -50v...because the transfo that i used was the original ATX power supply 500w transfo with EE35 number...and it was very surprising becoz the 12v became 50v (without center tap terminal)in my design..tnx
SMPS with output supply of +-70V for audio amplifierHide this!Advertise here!
AKM DAC Board, Silicone Image Clock Gen, 70V/4.4A SMPS Busyx2 Swap Meet 0 3rd June 2014 07:50 PM
power supply +/- 70v 5A fity Chip Amps 1 18th August 2012 07:34 AM
PFC for audio SMPS for Class D supply eem2am Power Supplies 44 17th April 2012 12:20 AM
Residual Current Limiter for 70V and 100V audio line Amplifier. ontoaba Solid State 9 23rd April 2010 12:12 AM
SMPS 12v to +-70V gcds Power Supplies 3 19th January 2009 04:55 PM
