diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   secondary in parallel/series with primary (http://www.diyaudio.com/forums/power-supplies/217752-secondary-parallel-series-primary.html)
scutterflux 11th August 2012 02:28 PM
What are the risks involved if I hook up a secondary in series with primary to theoretically increase primary windings to reduce output voltage?
vs.
What are the risks involved in hooking up the secondary in parallel and out of phase with primarys to reduce output voltage?
TonyTecson 11th August 2012 02:32 PM
such pratice is not encouraged here unless you are using isolation transformers, electricution hazards are real.......
DF96 11th August 2012 06:16 PM
Secondaries should only be connected in series with the primary, and only if those secondaries are not required for any other purpose and if they have sufficient insulation for mains potential. I would recommend attaching a label to the transformer to warn unsuspecting people that this has been done. In a few years time you may have forgotten what you did.
Never connect two windings in parallel (primary or secondary) except when they are identical.
Elvee 11th August 2012 07:02 PM
Originally Posted by DF96 (http://www.diyaudio.com/forums/power-supplies/217752-secondary-parallel-series-primary-post3123007.html#post3123007)
It is not generally the case: the mains safety isolation barrier is between the primaries and all secondaries.
The secondaries themselves often rely on the wire enamel for sole isolation material.
There are exceptions: transformers for oscilloscopes, variable frequency drives, etc, but no basic general purpose transformer is built like that.
DF96 11th August 2012 07:29 PM
Yes, I suspected that might be the case so the answer to the OP's question is No - unless you are absolutely sure your transformer is suitable.
scutterflux 11th August 2012 11:02 PM
So, the secondary is to only be hooked up in series if this is to be done.
The transformer is in a housing and sealed in an epoxy like substance (I assume to reduce vibration). When hooked up properly to 120V the (unused) secondary has 20V across it. I'm unable to see the actual wire that's wraped around the core, but the lead comming from it is rated for 300V, I don't trust that to be the rating of the secondary.
Is there another way to tell what the secondary's voltage rating is?
TonyTecson 12th August 2012 12:05 AM
use a dmm set to voltage to measure it....
a picture of your traffo can help....
zigzagflux 12th August 2012 02:52 AM
I do it all the time, works great when you have unused windings (especially that 5V winding intended for a tube rectifier). When you need to bring that voltage down just a little.
Best bet is to connect the secondary winding at the neutral end of the circuit, but ultimately I don't think there are extreme insulation concerns. If you were using the 5V winding (just as example) on a directly heated rectifier, no one panics about the insulation rating.
Keep in mind if your transformer is equipped with an electrostatic shield, using a secondary winding in the primary essentially negates the action of the shield.
darkfenriz 12th August 2012 11:21 AM
Originally Posted by Elvee (http://www.diyaudio.com/forums/power-supplies/217752-secondary-parallel-series-primary-post3123036.html#post3123036)
Yes, and that's why it is potentially lethal and definitely illegal. Unless you are absolutely sure it is not.
DF96 12th August 2012 03:43 PM
Most DMM measure voltage. I have never seen one which measures the voltage rating of insulation. For that you need something like a Megger.
That winding will have been built for high voltage operaton, because the transformer designer will know that a 5V heater winding is intended for a rectifier. Not all secondaries are.
Resources saved on this page: MySQL 18.75%
