#21 |
#22 | |
since you have a choke input filter, raw B+ is around 200vdc....you need to lose 90volts.. to cut down on voltage, you can put additional RC in the B+ line......it will be more effective that way in bringing ripple voltage down.... you can also use an 0A2 to shunt regulate the B+..... you can use higher valued resistors to bias your filament with dc voltage, say 270k to B+ and 82k to ground.....the junction connects to 2 470ohm resistors to each leg of the filament supply....this ensures that current drain is low... do not dump your traffo just as yet....resistors are cheaper.....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#23 | ||
Something like that, specifically I used 2 traffos with 230V secondary)
I didn't know something like this existed. I tried looking for a schematic on how to use it, no luck so far. Does it work like a Zener diode? Quote:
True. But I kinda went another way. I intend to use another tube (EL84), its operating point is more suited to my traffo, still waiting for the parts to come.
#24 | |
That looked like a handy tool. Unfortunately most things SS are a bit beyond me at the moment.
#25 |
I see you have a choke input supply. The formula I gave you was for a cap input supply. For a choke input supply it is much simpler: provided that you are taking enough current the effective DC resistance of the supply is just R's plus choke resistance etc. No factor of 5 (i.e. duty cycle) in front of R's, and the 0.005/C term disappears because the cap is being continuously charged.
#26 |
The effective 40Hz impedance of the last capacitor in the PSU is given as above by the formula
Z = 1 / 2 / Pi / Freq / C for 1mF//120uF the C=0.00112F Freq is stated as 40Hz. Pi ~ 3.142 Z ~ 3.6ohms. That is ~ 1/22 of the load resistance value. Well below 1/10 stated above. All the other factors are just small corrections to that 3.6ohms calculated. eg, esr raises it slightly. Preceding Capacitance lowers it slightly. Transformer impedance is probably not relevant. |
#27 | ||
#28 | |
#29 |
#30 |
There is no rule. It all depends on how much voltage you are willing to drop, and how much heat you are willing to dissipate in the power supply. Generally, you would want the PSU resistance to be signficantly less than the load resistance.
| Unregulated Power Supply | maxseeley | Vendor's Bazaar | 1 | 18th October 2011 06:41 PM |
| Speaker impedance vs output power | kubeek | Multi-Way | 10 | 2nd May 2011 08:25 PM |
| Measuring Output Impedance of Power Supply | korneluk | Tubes / Valves | 21 | 27th December 2010 09:58 PM |
| unregulated wallmart power supply cap size | ash_dac | Power Supplies | 11 | 17th August 2005 11:39 PM |
| ZV4 Impedance to Power Supply | Michael Rothacher | Pass Labs | 1 | 13th March 2003 10:47 AM |
