Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th August 2012, 03:21 AM   #11
Originally Posted by DF96 View Post
Are you asking about AC impedance or DC impedance?
Which one of these do I have to meet the 1:10 source to load ratio? Both?
For 50Hz supply and fullwave rectification the reservoir caps get recharged every 10ms. They then droop under load by roughly I x 0.01/C, but the average DC droop will be half this so effective DC resistance due to the reservoir cap is 0.005/C (e.g. 5 ohms for 1000uF).
Sorry I don't quite under stand this part. SO do I get 10 ohms for 2000uF?
Thanks again.
Old 10th August 2012, 06:25 AM   #12
godfrey is offline godfrey  South Africa
No, 2000uF => 2.5 Ohms, 10000uF => 0.5 Ohms etc
It's a nice rule of thumb.
Old 10th August 2012, 06:43 AM   #13
Thanks.
For the size power supply cap, here it talks about a rule of thumb of about 1000uF per 1A of current output. Is that a good number?
Solid State Power Amplifier Supply Part 2
Old 10th August 2012, 07:03 AM   #14
Tony is offline Tony  Philippines
Tony's Avatar
Originally Posted by Navyblue View Post
Thanks.
yes.....i have lots of caps so i use them on my tube amps as welll....
Old 10th August 2012, 08:23 AM   #15
jan.didden's Avatar
Thanks again.
I think we should realize that although we talk about a DC power supply, the load from an audio device is an AC load.
The Zout of a simple rectifier + cap is the impedance of the cap at the freq of the load signal. The formula has been given before and it is of course dependent on the freq of the signal you are amplifying. Meaning the Zout is highest at low freqs. So you probably want to size the cap for say 1/10 of an 8 ohms load at 20Hz. Just plug the numbers in the formula C=1/(2.pi.f.(0.8 ohms)).
Don't worry about DC Zout - it's pretty irrelevant for audio in this context.
jan didden
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 10th August 2012, 08:40 AM   #16
Thanks Jan.
So, we can completely ignore it? In my case, my transformer's secondary DC resistance is 220 ohms, and my DC load is under 1k ohms. If I plug the numbers into the formula I can't even hit 1:1 ratio let alone 1:10.
Old 10th August 2012, 08:46 AM   #17
Tony's Avatar
^what your figure means is that you will have bigger voltage drop with your load connected....
as long as you have your operating points achieved regardless you should be fine.....
it is not just secondary dc resistance of your traffo.....the primary dc resistance has an effect also.....
the kind of dc resistances you have is indicative of tube type psu's...
what are you building anyway? post some schematics and we will be able to help you for sure....
Old 10th August 2012, 08:59 AM   #18
Ok, this is my last iteration of the circuit, I intend to make some changes (no parts yet) but the general idea remains the same.
So this has a high PSU Zout and a low DC load. Please let me know everything that is wrong with it.
Old 10th August 2012, 10:27 AM   #19
Tony's Avatar
aha....just as i suspected.....
what are the dc resistances of your chokes?
110v at 30mA is a 3.7k load
your total load is 70mA......this is in series with your chokes so you have to consider that also...
you want to know what your raw secondary ac is? right?
Old 10th August 2012, 11:52 AM   #20
Thanks again.
The power transformer is rated at 230V, when loaded it is around 200V. Secondary windings DC resistance is 220 ohms per winding.
Chokes' DC resistance is 90 ohms for both.
The chain of 390 ohms resistors, it draws about another 70mA.
If you wonder why the resistor chain is wasting so much current, I did this to cut down the supply voltage. If you wonder why I didn't cut voltage the usual way (putting them in series with the chokes), I observed a noticeable improvement in bass when comparing between the 2. I thought it interesting, and this made me look into the effect of Zout of PSU. But this also keep the load DC resistance low, so I plan to get rid of it.
Of course in theory I should just dump the power transformer, replace it with one with appropriate rating, and do without the resistors. but that cost money.
So total current draw is around 140mA, at 110V, it would be about 786 ohms overall.
Unregulated Power Supply maxseeley Vendor's Bazaar 1 18th October 2011 06:41 PM
Speaker impedance vs output power kubeek Multi-Way 10 2nd May 2011 08:25 PM
Measuring Output Impedance of Power Supply korneluk Tubes / Valves 21 27th December 2010 09:58 PM
unregulated wallmart power supply cap size ash_dac Power Supplies 11 17th August 2005 11:39 PM
ZV4 Impedance to Power Supply Michael Rothacher Pass Labs 1 13th March 2003 10:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
