Hello
I have just taken delivery of an Anti - Mode 2.0 Dual Core Audio Processor with Room Correction unit and it has been supplied (for the UK) with a 9VAC wall wart as power supply. Does anyone know of any company in the UK that makes better quality replacment power supplies ? Failing that would a high quality 9V battery power supply be an option ? Again if you either know of a simple design or anyone that supplies ready made versions would appreciate the information / links . |
#2 |
Well if its an AC wall wart, all the rectification/regulation etc is internal. The wallwart then is just a transformer and can be replaced (if you think it sounds better) with another xformer.
Maybe you should just live with it for a while. In low power apps like these, it is unlikely that another xformer would have any audible impact, be it for better or worse. Remember that wall arts genrerally have a very good build-in isolation against mains borne noise, in any case better than a xformer as such. jan
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
| Lancing a wall-wart. | raypalmer | Power Supplies | 2 | 19th May 2011 01:26 AM |
| Wall wart alternative/AC power supply design & housing questions | ew | Power Supplies | 9 | 31st October 2010 10:21 PM |
| best wall wart for t-amp, where? | gychang | Class D | 3 | 2nd October 2006 12:06 PM |
| Wall wart charger as supply | rtarbell | Parts | 1 | 9th August 2006 07:47 AM |
| Wall Wart Tube Power | jackinnj | Tubes / Valves | 10 | 24th December 2005 03:01 PM |
