20 Khz 800 volts power supply for ultrasonic welder - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th August 2012, 05:21 AM   #1
mehrdad is offline mehrdad  Iran
mehrdad's Avatar
Default 20 Khz 800 volts power supply for ultrasonic welder
Hello every one.
i have a sonimat gm 2010 power supply that is supplying an ultrasonic welder that welds nonwoven materials.
i want to build a circuit to replace this power supply.
the output is 20khz in 800 to 1000 volts ac.
can anyone give me a circuit?
thanks.
Old 6th August 2012, 06:03 AM   #2
Look for sine wave inverter schematics. I am not sure if the ultrasonic welder uses sine wave but is most probable.
Having the diagram of the inverter, just modify the output voltage by changing the number of turns.
Also be aware that the power required from this supply is also to be considered.
Gajanan Phadte
Old 6th August 2012, 06:12 AM   #3
mehrdad's Avatar
i have probleme with Saturation of ferrit outout transformer.
because of that the power switches blow up.
can you give me calculations for EE ferrits and number of turns?
for 600w power.
Old 6th August 2012, 06:30 AM   #4
I'm way out of my depth here, but the transformer probably needs a gap to avoid saturation.
I may be barking up the wrong tree, but at least I'm barking!
Old 6th August 2012, 06:50 AM   #5
mehrdad's Avatar
yes you`r right.
but if i have currect calculations it will be better.
Old 6th August 2012, 06:57 AM   #6
jcx is online now jcx  United States
things could be a bit complicated - the piezo ceraimc stack can want to see a series L to cancel some of the stack's C - but the maker sugests some controllers are "smart" - so you may need broader band drive to the stack to allow the controller's tuning of the drive for the mechanical parts resonance properties
I would want to see the exitsing unit schematic before recommending a replacement
Old 6th August 2012, 07:15 AM   #7
mehrdad's Avatar
here is the welder schematic
Old 6th August 2012, 07:20 AM   #8
mehrdad's Avatar
Old 6th August 2012, 07:21 AM   #9
mehrdad's Avatar
Old 6th August 2012, 07:46 AM   #10
So do you plan to use this in a piece of hifi gear????!!!!!
20 Hz to 20 kHz Dipole Speaker System MJK Full Range 69 29th September 2008 02:37 PM
Copyright 1999-2017 diyAudio
