Hi, looking for simple DC-DC variable voltage and current lab power supply circuit. variable voltage (around 3 to 12 volts) and variable current. (current limiting with LED indicator) Also I will add digital voltmeter and ammeter module. Regards, BT
#2 |
What input voltage?
What output current? |
#3 |
input voltage is around 12 volts (I have small smps with 12v / 2amp output) Now I want a dc-dc simple circuit for the following output voltage mainly between 3-9 volts. output current 0-2 amps (with limit and led indicator) I will add voltmeter and ammeter BT
#4 |
Looking for the circuit. using L200 or similar IC. LM317?
#5 |
There are 3A versions of the LM317, I believe the type # is like LM337?
There will be app circuits for what you want in the data sheets. Edit: try LM350T jan didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun Last edited by jan.didden; 31st July 2012 at 03:31 PM. |
#6 |
thanks. I am not getting the right circuit voltage & current limit with current over limit indicator. Could you or some one please send me one. BT
#7 |
Each one of these pdf’s has a power supply with voltage and current adjust.
http://www.zlgmcu.com/on/ds_ldo/LM350-D.pdf Fig 21. http://www.ti.com/lit/ds/symlink/lm350-n.pdf Page 11. |
#8 |
Why build when you can buy it so cheaply these days? What you want will cost you about $15 on eBay; how many hours will you spend designing and building it? And how much money for parts? Don't get me wrong, I enjoy DIY and that's why I am here and why we are all here. At some point though I decided to stop building tools so I could focus on the 'real' projects. That's just me. If you want to build a power supply, build it.
Try searching eBay for "DC Buck Converter Constant Voltage Current Voltmeter Ammeter". It isn't a finished product, you'll need to supply the DC input power supply, an enclosure, you will likely want nice panel mounted pots for volt/current control instead of the PC mount ones, etc. So it is half a DIY project. |
#9 |
12V-3V=9V; @ 2A that is 18W of heat. Have you considered a buck converter?
All the trouble I've ever been in started out as fun......
#10 |
@macboy Thanks for your reply. If possible send me ebay link which does variable voltage & current with over limit led indicator. @CBS240 I am considering all options. If possible send me info or pointers. Thanks, BT
| Wanted: variable voltage dual output dc power supply | giantslalom | Vendor's Bazaar | 0 | 9th September 2011 06:18 PM |
| Variable DC power supply to drive TT motor | IZHAKKATZ | Analogue Source | 9 | 9th April 2009 08:33 PM |
| Regulated Lab DC power supply | Sir Trefor | Tubes / Valves | 6 | 28th July 2007 06:13 PM |
| High Current Variable Voltage Power Supply | real | Power Supplies | 9 | 24th February 2005 10:53 PM |
| High current DC power supply | nikogian | Solid State | 1 | 26th March 2004 08:03 PM |
