Ventilating Transformers
Old 28th July 2012, 03:29 PM   #1
astrouk1 is offline astrouk1  United Kingdom
Default Ventilating Transformers
I have two transformers, one is 120VA, the other 7VA. I want to encase them in aluminium covers I've made, which give about 4mm clearance around each of the transformers. My plan was to cover the cases in MuMetal shielding.
Is it advisable to drill ventilation holes in the base and top? Will this affect the shielding properties of the MuMetal?
The transformers will not be highly loaded, I'm thinking this will be like an encapsulated transformer. Hopefully the experts can give me advice on this one. I'd rather not drill them unless it's advisable to do so.
Many thanks for any advice.
Old 28th July 2012, 03:39 PM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
If they are lightly loaded you should not need the ventillation holes.
Try them. See if they get too warm.
Old 28th July 2012, 04:22 PM   #3
DF96 is offline DF96  England
Any working of mu metal can reduce its shielding properties, which in any case is only good for fairly low fields. Put mu metal around the things which need to be protected from the field, not the source of the field. For a power transformer a belly band is probably a better way to reduce any external magnetic field.
Old 28th July 2012, 04:28 PM   #4
Both the transformers have a GOSS Band and an Electrostatic shield.
I'm building the power supply, once I finish the Beta 22 unit, I'll see how hot they get at full load.
Old 29th July 2012, 10:06 AM   #5
barrymagrec is offline barrymagrec
Like DF96 says. mu metal is the wrong material for power transformer screening, if you really need to, use stalloy or similar materials.
Old 29th July 2012, 12:21 PM   #6
Jay is offline Jay  Indonesia
Banned
Originally Posted by barrymagrec View Post
mu metal is the wrong material for power transformer screening..
What is a mu metal? That grey alloy plate? It has been used for ages to screen transformers, as well as line-level amplifiers. In transformers by transformer's manufacturer, and around sensitive amp (not around transformer) by device manufacturer. Rarely I have seen mu-metal used to "screen" transformer.
In RF devices, I only found aluminum block (no mu-metal), may be mixed with silver. Once I found gold for shielding
Old 29th July 2012, 01:02 PM   #7
Mu metal is a specific alloy containing nickel, iron, copper and chromium. It is specifically designed for low level screening, for instance tape heads and microphone transformers and is very effective. It is little use for power transformers since it easily saturates at higher flux densities and becomes inefective. It also requires heat treatment after any bending or machining which makes it difficult for the DIYer. Since it is a greyish alloy it is not easy to identify visually but it is a fair bet that any screening can round a power transformer is not mu metal.
RF screening is an entirely different problem and skin effect makes the use of copper, aluminium and even silver and gold effective.
Old 29th July 2012, 02:28 PM   #8
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Old 29th July 2012, 03:12 PM   #9
Exactly - that`s a screening can made of ?????
Old 29th July 2012, 03:31 PM   #10
Rolf Gemein has been using Mu covers on toroidal transformers for 25 years.
Difference is that these have 1mm wall thickness and are ready made (require a clamp to hold them to the case)
Ventilating TransformersHide this!Advertise here!
Making CT transformers from two transformers infernal Parts 1 14th July 2011 08:42 AM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
Transformers...which ones? Doovieman Chip Amps 5 3rd August 2004 07:07 PM
Would these transformers be of any use to me? :D SkinnyBoy Solid State 14 9th June 2003 11:35 AM
